Will these fit??
Posted: Sat Nov 29, 2008 9:58 am
by Loopy Chipmunk
Hi everyone, New member here, just received our new (used) 05 vibe today. My question is that it has 16" alloy's....a friend of mine has some winters with rims and can't use then on his new car. Would 15" rims with 215/65/R15 tires fit, i think the bolt pattern is 5x110mm? Is there any harm running a 15" rim?Cheers!
Re: Will these fit?? (Loopy Chipmunk)
Posted: Sat Nov 29, 2008 10:22 am
by Raven
WELCOME TO GENVIBE The tires are quite a bit too large in diameter, 4.35% and 3% is the recommended limit. They may even rub on the fender liners. As for the wheels, if they are 5x100 they'll probably fit, depending what kind of car they were on. Most Vibers use 15" Toyota Corolla rims with 195/65/15
Re: Will these fit?? (Raven)
Posted: Sat Nov 29, 2008 10:26 am
by ou.grizzly
Quote, originally posted by Raven »WELCOME TO GENVIBE The tires are quite a bit too large in diameter, 4.35% and 3% is the recommended limit. They may even rub on the fender liners. As for the wheels, if they are 5x100 they'll fit. Most Vibers use 15" rims with 195/65/15Remember Project "Big Boots"?
Re: Will these fit?? (ou.grizzly)
Posted: Sat Nov 29, 2008 1:16 pm
by Raven
Quote, originally posted by ou.grizzly »Remember Project "Big Boots"? Yes I do, MadBill is my brother. His 275/40/17 tires are only 3.08% too large while 215/65/15 is 4.35% too large. We're not talking width here, we're talking overall diameter.
Posted: Sat Nov 29, 2008 1:59 pm
by ou.grizzly
Quote, originally posted by Raven »Yes I do, MadBill is my brother. His 275/40/17 tires are only 3.08% too large while 215/65/15 is 4.35% too large. We're not talking width here, we're talking overall diameter.Wow, did not know that! I was just remembering his project thread and was not sure if he had to trim the inside wheel well. Was not questioning your dimensions or numbers.
