Wash then rinse sounds self defeating
Posted: Fri Nov 28, 2008 4:19 am
by Vibrator08
At a carwash the machine waxes then rinses, doesn't that just wash the wax off?
Re: Wash then rinse sounds self defeating (Vibrator08)
Posted: Fri Nov 28, 2008 6:34 am
by Wolfman213
I'm not a detail guru, either northvibe or sublimewind is, can't remember which one, but if they were to simply leave the wax on there, it would probably do more harm to your car than good. It's probably formulated different than wax that you would normally put on your car. Next time maybe you should get everything but the wax and see how the car is and then do another one with the was and see if you can tell a difference.
Posted: Fri Nov 28, 2008 7:59 am
by psiu
I think with those the idea is pressure and heat to get some wax on the car, then the cold to run the excess off and solidify the wax on.Either way I know it's doing a crappy job but I live in an apt complex so *shrug*
Posted: Tue Dec 09, 2008 10:47 pm
by Sublimewind
Old post, but i'll take a crack at it anyway.. Car wash wax is of the lowest quality and QUANTITY out there.. obviously it's transported to the surface by a water "like" substance, though wax and water don't mix.. When the wax comes out of the "gun" it's at such a high rate of speed, it's like doing a light wax job and buff on the car... That's the kicker though, it's sooooooo very light... and why it wears away so quickly.. the rinse is to simply remover whatever fluid is used to transoport the wax, as it couldn't be transported in pure water, it would seperate in the tank and you would get nothing but water...
Re: (Sublimewind)
Posted: Tue Dec 16, 2008 10:52 pm
by Whelan
It's almost like the spray and wax you can put on your car after a wash. It simply goes on, rinses or wipes off and gives your car a false sense of being waxed. i.e. that smooth feeling you have. But it does nothing for protection of the paint.
Re: (Whelan)
Posted: Wed Dec 17, 2008 12:38 pm
by vibolista
Us Vibers with bare cladding would probably be better off to forgo any Car Wash Wax. Any wax on the plastic can't good, even if it didn't last very long, since the plastic is somewhat porous, right? I only go to a Car Wash as a last resort and then never select the 'wax' option.
Re: (vibolista)
Posted: Thu Dec 18, 2008 12:45 am
by Whelan
Its in my Ten Commandments of don'ts. Going to a self spray bay is fine, or even a touchless. But if you drive through the brushes, have fun getting the swirls out.
