Oil Filter Wrench
Posted: Mon Nov 24, 2008 7:36 am
by to106
Which Filter wrench works the best for removing the oil Filter? I have a typical metal filter wrench which keep slipping, and this time I could not use my own grip to make it loose. It's on really tight. I had to pack up and will try again next week.
Re: Oil Filter Wrench (to106)
Posted: Mon Nov 24, 2008 8:25 pm
by keithvibe
this is the type of filter wrench you needIt will only get tighter the more you wrench on it
Re: Oil Filter Wrench (keithvibe)
Posted: Tue Nov 25, 2008 2:23 am
by Sublimewind
Don't forget these badlads either... they work at odd angles to... you don't have to be straight on...
Posted: Tue Nov 25, 2008 3:13 am
by harryyiii
I have the type that has a 3/8" drive, and is a socket cup that slips over and matches the bolt type pattern formed on the end of the filters. Works great, as all the muscle work is below the engine.
Re: Oil Filter Wrench (harryyiii)
Posted: Tue Nov 25, 2008 4:43 am
by breezd
Quote, originally posted by harryyiii »I have the type that has a 3/8" drive, and is a socket cup that slips over and matches the bolt type pattern formed on the end of the filters. Works great, as all the muscle work is below the engine. I have the same thing, works like a charm. And it was only a couple bucks at Autozone.
Re: Oil Filter Wrench (breezd)
Posted: Tue Nov 25, 2008 10:01 am
by to106
I bought this socket cup, and is made out of graphite so must be strong. I also tested on the similar oil filter and fits very snug. I will try this weekend and hopefully it will work.Thank you all for the input.
Posted: Tue Nov 25, 2008 12:17 pm
by Herb
Quote, originally posted by to106 »I bought this socket cup, and is made out of graphite so must be strong. I also tested on the similar oil filter and fits very snug. I will try this weekend and hopefully it will work.Thank you all for the input.I've been using that type for the past few years and I think it works great
