Auto polishing appliance
Posted: Mon Nov 24, 2008 7:09 am
by vhoward1122
http://tinyurl.com/68byv2I bought a 6" orbital polisher. It came with a variety of bonnets to use for polish application, removal, and buffing.It seemed to go faster and I got a more even coat of polish than when I did it by hand. I like the results, but was wondering what everybody else thought about these machines?
Re: Auto polishing appliance (vhoward1122)
Posted: Tue Dec 16, 2008 11:00 pm
by Whelan
I use a Meguiar's G100 Dual Action Orbital Polisher on my car. It has 6 speeds which helps immensely!Bottom line is anything orbital or electric will ensure not just a more even coating but also a better breakdown of the product to be more effective. Look into using polishes and waxes designed for orbital use over hand use. I stick with the Meguiar's Professional line (tan bottles mostly available online) such as #83 and #80. I use the higher speed of 5 for the polishing and swirl removal. Then down to a low spead 3 for the wax application since you are top coating the paint for protection at that point. Be sure to apply good pressure to when using the machine. Just letting it glide over the car does nothing. Also change up your pattern to ensure full coverage. I do my sections in a 2x2 square going up and down then switching to left and right. I repeat and then remove the product.
Re: Auto polishing appliance (Whelan)
Posted: Wed Dec 17, 2008 12:20 pm
by vibolista
Does the Meguiar's G100 come with bonnets? What kind(material), do you recommend?
Re: Auto polishing appliance (vibolista)
Posted: Thu Dec 18, 2008 12:50 am
by Whelan
It came with one #8006 foam pad. It does not use Bonnets. The backing plate has velcro that the Meguiar's pads stick to. I replaced the hard backing plate with a flexible one to allow more movement in tighter areas. I use the Meguiar's 8006 pads for swirl removal and polish. Then I use the 9006 soft buff foam pads for the final wax. Every so often I have a nylon brush that I turn the machine on low speed and from the center work my way out with it on to clean off the excess on the pad that gets built up. Pads can be washed in warm water, but after a few washes the velcro stick wears off. They are cheap though so I have extras. And never NEVER use the same pad with a different product. I took a magic marker and on the back of the pad wrote the product # that goes with it, i.e. #83 or #80 or #26.
Posted: Thu Dec 18, 2008 3:59 pm
by vibolista
Makes sense, thanks. I need to get a new polisher. Meguiars produce good stuff.
Posted: Fri Dec 19, 2008 1:03 am
by Whelan
Meguiar's has a new version out, the G150 I believe its called. The unit I have is about $150. If you don't want to order one you can go to Lowes and get a Porter Cable 7424. IT is the same exact unit but the Meg's one comes with a lifetime warranty.
Posted: Fri Dec 19, 2008 12:02 pm
by vibolista
Cool, Whelan. Next time I get to Lowes I'll look the Porter Cable up. Thanks!
Posted: Sun Dec 21, 2008 11:31 pm
by Whelan
Do yourself another favor. If you get the PC or the Meg's, Pick yourself up a Fleixble backing plate. It is 100% better. I get all my Meg's products from this place.http://www.autodetailingsolutions.com
Posted: Mon Dec 22, 2008 12:28 pm
by vibolista
Will do. Is the flexible backing plate in the autodetailingsolutions.com site?
Posted: Fri May 01, 2009 6:57 am
by joholste
the new megs is the G110. I would also suggest looking at the Porter Cable 7424 which is the same thing as the G100, and you can usually find it a little bit cheaper. both machines work wonderfully.
