Camaro Rims?
Posted: Thu Nov 20, 2008 12:12 am
by Zer0VIBE03
So my dad has some 16" Camaro rims sitting around at home (Winter tires for his T/A) and the bolt pattern is 5x120.7 whereas on the Vibe it's 5x100. If I wanted to use those rims, could I? If so, what's required to make them fit? I mostly just need the tires which are 225/60/16, but it would be nice to have some 5-spokes with them. Any help?
Re: Camaro Rims? (Zer0VIBE03)
Posted: Thu Nov 20, 2008 8:03 am
by Raven
The wheels would require some adapter plates, most likely custom made. Not practical at all. The tires are waaaay too big in diameter to use on the Vibe. Stock is 205/55/16 and 225/60/16 is 6.58% larger. The maximum recommended difference is 3%. Check out my brother's "Project Big Boots" Vibe with 275/40/17 tires and custom made adapter plates.
http://forums.genvibe.com/zerothread?id ... ad?id=3150
