2004 Vibe P0456 Check Engine Code
Posted: Wed Nov 19, 2008 1:43 am
by mzielinski
This morning had my check engine light go on. Code is P0456? Anyone had this issue in the past? How do I fix it?
Posted: Wed Nov 19, 2008 1:55 am
by northvibe
http://forums.genvibe.com/zerothread?id=31237there you go, some help from another member that had the same issue. Vacuum lines???Welcome to genvibe
Re: (northvibe)
Posted: Wed Nov 19, 2008 1:57 am
by mzielinski
Thank you so much.....I really appreciate it!!
Posted: Wed Nov 19, 2008 2:24 am
by northvibe
no prob. although the most "common" cause is your fuel cap isnt tightened all the way. unscrew it and rescrew it in making sure it clicks a couple times. I usually make sure mine is at like 3-6 clicks
