Tango Charlie 2003 Vibe
Posted: Wed Nov 12, 2008 12:12 am
by Tango Charlie
This is my daily driver, Olivia;Like Trikkoncepts, I'm after MPGs. My grille block just isn't as fancy. I run my tires at max sidewall, but even with it being a 5 speed, I'm averaging about 38 MPG. 20 mile commute, not highway like Triks. It doesn't show up in the pics, but the front end is pretty nicked up. Lotsa stone chips. I've done the 'cut the yellow wire' DRL-delete mod. I like it. I've checked out the site from time to time, thought I'd make a first post.
Re: Tango Charlie 2003 Vibe (Tango Charlie)
Posted: Wed Nov 12, 2008 12:30 am
by mac99d
Look’s real clean. So how much of a fuel savings do you get with the deflector? Have you done a comparison between the two on or off, and are there any overheating issues?
Posted: Wed Nov 12, 2008 1:09 am
by bull77
Nice job and vibe....you're not alone, my front end is also beaten up with stone chips and scratches
Posted: Wed Nov 12, 2008 2:32 am
by Tango Charlie
Thanks, guys.I've had the grille block installed since September. No temperature issues at all. I've got a ScanGauge II installed (one parameter it displays is coolant temp), so I'm going to go ahead and start blocking off the lower opening, too, now that it's getting cooler...I've noticed a solid 1-2 MPG increase with the block installed. Not a lot, but every little bit helps. You can see a picture-laden thread of its installation here; http://ecomodder.com/forum/sho....html
Re: (Tango Charlie)
Posted: Wed Nov 12, 2008 3:04 am
by pick41
Good looking Vibe, nice to see another Hoosier.
