Problem with the '04 Pontiac Aztek Rally AWD
Posted: Mon Nov 03, 2008 10:54 pm
by BlueCrush
I posted this on a Aztek forum last night, but I thought I might be able to tap into the Knowledge base here to see if anyone else has heard of this issue before. I am getting Zero engine codes. Here is what I posted on the Aztek forum:Hey, everyone! I have an '04 Aztek Rally. Bought it new in '04. I have recently been experiencing some issues. I did some searches and found out and tried a few things that were suggested the problem went away for a week but now it's back. Here is what happened. The drivers side rear tire developed a small air leak and at some point my low tire warning light came on a short time later the same day the Anti-lock brake and AWD disable lights came on. So I searched on the forum that a low tire can sometimes cause those light to go on. So, I had the tire repaired, reset the low tire light. Drove the car straight and turned it off, turned it back on and all the warning light went away. So, I thought, cool! that must have been it. WRONG! This evening both the AWD disable and Anti-lock brake lights came back on but also I am now experiencing a loss in power when I go over 1/3 - 1/2 throttle. It is like the tranny is disengaging or something. So it must be something else. I already checked all fluids and everything is good. Does anyone know of any TSB's or experienced these same problems at the same time? From what I have read on the Aztek forum, there are a couple possibilities it could be: Head Gasket, Intake Gasket or Wheel Hub(s) maybe something else as well...
Re: Problem with the '04 Pontiac Aztek Rally AWD (BlueCrush)
Posted: Mon Nov 03, 2008 11:23 pm
by Whelan
I didn't know there was such a thing as an AWD disable light
Re: Problem with the '04 Pontiac Aztek Rally AWD (Whelan)
Posted: Mon Nov 03, 2008 11:39 pm
by BlueCrush
Quote, originally posted by Whelan »I didn't know there was such a thing as an AWD disable lightYeah it shows up on the Driver LCD info screen. Bright as hell!
Posted: Tue Nov 04, 2008 12:26 am
by northvibe
if ABS light and AWD light are on, couldnt that trigger the computer ie ecu to tell the car not to perform as high as to not get into serious trouble? Maybe that tires ABS needs to be checked/cleaned up? IMO sounds like a sensor isnt reading right and is triggering those errors so you cant drive to fast and get into a situation where you'd need awd/abs.
Re: (northvibe)
Posted: Tue Nov 04, 2008 12:42 am
by BlueCrush
Quote, originally posted by northvibe »if ABS light and AWD light are on, couldnt that trigger the computer ie ecu to tell the car not to perform as high as to not get into serious trouble? Maybe that tires ABS needs to be checked/cleaned up? IMO sounds like a sensor isnt reading right and is triggering those errors so you cant drive to fast and get into a situation where you'd need awd/abs.That is what I am hoping. I am trying to find someone locally to borrow an ABS scanner so I don't have to buy one.
Re: (BlueCrush)
Posted: Tue Nov 04, 2008 1:03 am
by keithvibe
are the sensors in the wheels Brian?Could be just a bad sensor triggering your ordeal.
Posted: Tue Nov 04, 2008 1:20 am
by northvibe
do the auto part stores do the free scans on those as well or just cel's?
Re: (northvibe)
Posted: Tue Nov 04, 2008 1:52 am
by Whelan
Both the AWD and ANTI-LOCK systems take input from speed sensor on each wheel. Could be a sensor (part of wheel bearing/hub assembly) is bad
Re: (Whelan)
Posted: Tue Nov 04, 2008 2:04 am
by keithvibe
keep in mine he is talking about an Aztek not a vibe or matrix. could be a different system
Re: (keithvibe)
Posted: Tue Nov 04, 2008 2:24 am
by BlueCrush
Quote, originally posted by keithvibe »are the sensors in the wheels Brian?Could be just a bad sensor triggering your ordeal. The sensors are built into each wheel hub. If the sensor goes, you need to replace the entire hub. they sell for approx $50-$75 shipped on Ebay.Quote, originally posted by northvibe »do the auto part stores do the free scans on those as well or just cel's?No the local auto parts stores no longer offer free scans.Quote, originally posted by Whelan »Both the AWD and ANTI-LOCK systems take input from speed sensor on each wheel. Could be a sensor (part of wheel bearing/hub assembly) is badCorrect. That is why I need an ABS scanner to find out which one(s) the culprit.Quote, originally posted by keithvibe »keep in mine he is talking about an Aztek not a vibe or matrix. could be a different systemI think Adam is referring to the Aztek.
Re: (BlueCrush)
Posted: Tue Nov 04, 2008 10:48 pm
by Whelan
Yeah I was referring to that. I posted that as I had found it after googling "ABS and AWD light on an Aztek" Best way to find things on google is to be vague.
Re: (Whelan)
Posted: Thu Nov 06, 2008 6:59 am
by BlueCrush
We'll I just bought an ACTRON CP9449 ABS BrakeScan OBD II 2 Scanner tool on Ebay. I did not find anyone in my area that had one of these to borrow to use. I figure it will save me money in the long run and it will read OBD2 codes so I can sell my other one.
Re: (BlueCrush)
Posted: Mon Nov 10, 2008 8:11 am
by BlueCrush
Well my nbew scanner came today and it pulled a code for the front passenger side wheel speed sensor malfuntion. I'm going to take a closer look at it tonight to see if the wire or connector is just corroded or possibly a bad hub.
Re: (BlueCrush)
Posted: Mon Nov 10, 2008 8:13 am
by keithvibe
do i see a forsale item in the near future? lol JK... glad your making head way on your issue. even though it's on the worlds ugliest vehicle. HAHAhttp://
www.grupthink.com/topic/23
Re: (keithvibe)
Posted: Mon Nov 10, 2008 9:00 am
by BlueCrush
Quote, originally posted by keithvibe »do i see a forsale item in the near future? lol JK... glad your making head way on your issue. even though it's on the worlds ugliest vehicle. HAHAhttp://
www.grupthink.com/topic/23For my other Actron CP9125 Code reader....YES. I'll be posting it for sale tonight. This is the exact one we have:
Re: (BlueCrush)
Posted: Mon Nov 10, 2008 9:06 am
by keithvibe
Quote, originally posted by BlueCrush »This is the exact one we have:dude...honestly shouldn't brag HAHAHA what did you find out, a lose wire, hopefully
Re: (keithvibe)
Posted: Mon Nov 10, 2008 9:12 am
by BlueCrush
Quote, originally posted by keithvibe »dude...honestly shouldn't brag HAHAHA what did you find out, a lose wire, hopefullyWhat! That pic is Hawt! I can guarantee it will never be stolen! Hahahaha! No one want to steal the Pumkin Mobile!
Re: (BlueCrush)
Posted: Mon Nov 10, 2008 9:20 am
by keithvibe
Quote, originally posted by BlueCrush »What! That pic is Hawt! I can guarantee it will never be stolen! Hahahaha! No one want to steal the Pumkin Mobile! your right, it does kinda look like jack-O-lantern
Re: (keithvibe)
Posted: Mon Nov 10, 2008 10:18 pm
by Kamikaze
Actually it is throwing a code:BADOMENDON'TSELLVIBE
Re: (keithvibe)
Posted: Mon Nov 10, 2008 11:54 pm
by BlueCrush
Quote, originally posted by keithvibe »your right, it does kinda look like jack-O-lanternI should put some yellow LED's behind the grille. Then it would look just like a pumpkin.
Re: (Kamikaze)
Posted: Mon Nov 10, 2008 11:59 pm
by BlueCrush
Quote, originally posted by Kamikaze »Actually it is throwing a code:BADOMENDON'TSELLVIBEIt actually came up with a C0040 code which means SHUTYOURPIEHOLE....hahahahaNo really it was a RF wheels sensor circuit malfunction. So, I'm takign the wheel off tonight and cleaning out the sensor and checking for any bad connections. I'm also going to check to see how hard it would be to change out the wheel hub/bearing/sensor (yes it's all in one). I also found out that I may qualify for a re-imbursement from GM under a special policy #. So, I will be checking into that as well.
Posted: Tue Nov 11, 2008 1:21 am
by northvibe
OH for sure check into that special. My gf's honda has 130k miles, just threw these 2 cel's...I come to find a TSB that says it covers those for 14yr or 150k miles!!! So free fix
Otherwise it would be about 300 in parts :/ plus my labor..which is free for her of course..
Re: (northvibe)
Posted: Fri Nov 21, 2008 7:06 am
by BlueCrush
The Pumpkinmobile is fixed!!!!!!!!!!!!!!!!!!!! I bought a new hub with a built-in speed sensor from Ebay for $45 shipped to me. I was going to install it myself but I tweaked my neck so I called around and the Goodyear service station that installed my pulleys and tires a couple times said they would install it for only $103. So total bill was only $148 vs. other garages at $400 & the dealer at $600. Works for me!!The anti-lock brake and AWD disable lights went off right away and it also took the Aztek out of limp mode so everything is back ot normal!
Re: (BlueCrush)
Posted: Fri Nov 21, 2008 8:18 am
by keithvibe
whoot the great pumpkin has been fixed. now sell it instead of the vibe LOL
Posted: Fri Nov 21, 2008 11:09 am
by Tonyk27
Glade everything worked out.
