how do i replacae my foglight bulbs!?!?!?!?
Posted: Sun Nov 02, 2008 8:40 am
by ramenboy...
ok, so a couple weeks ago, i realized the aftermarket headlight bulbs i had were running too hot and melted the h4 socket on the passenger side.finally with some mild weather this weekend, i picked up a pair of high-heat sockets, replaced the stock ones, put in new bulbs and all was good. then i saw that i have a burned out stock fog light. so i picked up some 9006 bulbs hoping to replace the set, BUT i can't get to the freakin lamps from behind!! anyone replace their fogs? i thought this would be easy...
Posted: Sun Nov 02, 2008 8:48 am
Re: how do i replacae my foglight bulbs!?!?!?!? (ramenboy...)
Posted: Sun Nov 02, 2008 9:09 am
by keithvibe
twist and unplug, simple as that
Posted: Sun Nov 02, 2008 10:31 am
by ramenboy...
yeah but how do i get to them... do i have to take off the plastic well liner in front of the wheels? that would be a pisser if i did... or do i try to reach down from the engine bay? then i think i need 4 foot arms
Re: (ramenboy...)
Posted: Sun Nov 02, 2008 10:46 am
by keithvibe
take out the two 10mm bolts holding in the plastic liner just under the bumper. you don't need to remove the entire liner.Once you have the liner moved out of the way by pulling it down twards the ground you can access the bulbs very easy.
Re: (keithvibe)
Posted: Sun Nov 02, 2008 12:17 pm
by hskater26
i just reached up in there underneath the bumper....skinny arms/hands helped lol
Re: (hskater26)
Posted: Sun Nov 02, 2008 9:24 pm
by Kamikaze
put on hoist, walk under car... twist and pull.
