Need help on my vibe ( video inside)
Posted: Tue Oct 14, 2008 3:37 am
by 03vibegt-r
My vibe is making this terrible noise and anyone i talk to who has a 2zz engine says that the have never had a problem with there engine can some please give me some advice on what to look at or even a rebuild??http://www.mievo.net/mitsujoe/vibe.wmvAny help is appreciated , vibe is no longer for sale , thank you
Posted: Wed Oct 15, 2008 2:35 am
by 03vibegt-r
making a bad noise look at my for sale post car is no longer for sale until i get the engine fixed .http://www.mievo.net/mitsujoe/vibe.wmvany help would be appreciated , thank you
Re: Need help on my vibe (03vibegt-r)
Posted: Wed Oct 15, 2008 4:09 am
by 03vibegt-r
i really could use some help anyone??? motor is knocking very bad
Posted: Wed Oct 15, 2008 4:21 am
by kevera
Wow,that doesn't sound good!!!It could be 1 of 2 things.First check your belt tensioner,see if the hydraulic shock is bouncing up and down.Second,you are fubared and you have some serious rod knock.Hoping it's not the second.
Posted: Wed Oct 15, 2008 5:14 am
by ou.grizzly
For some reason it sounds different that KerryKerry'sAnd if you do need an engine; I would check the local bone yards around Bay City, there probably are a few good 2ZZ engines there with low miles.
Posted: Wed Oct 15, 2008 6:04 am
by 03vibegt-r
where in Michigan are you from ou.grizzly??
Re: (03vibegt-r)
Posted: Wed Oct 15, 2008 6:27 am
by ou.grizzly
Quote, originally posted by 03vibegt-r »where in Michigan are you from ou.grizzly??Metro Detroit Area...A pick-n-pull engine is more reasonable than a rebuild if you go that route.
Posted: Wed Oct 15, 2008 6:35 am
by 03vibegt-r
reply well if you find one let me know i need it soon so i can have a 12 sec vibe na
Posted: Mon Oct 20, 2008 11:30 am
by 03vibegt-r
ok update on the vibe the #4 rod bearing washed out but i caught it just in time to be replaced im going to replace all rod bearing then it will be up for sale after i put some miles on it , i will do a step by step on taking apart the bottom en with out pulling the eninge to replace bearings. now im very excited to know its not the crankshaft bearing just the rod beaings , i will offer a rebuild service to anyone who has a vibe for 250 to replace the rod bearing as i see this is becoming a common problem
Re: (03vibegt-r)
Posted: Wed Oct 29, 2008 5:30 am
by Merzbow
Oh god, that noise!!! That's the noise my engine made before all the internals fried (removed)...I had to replace my entire engine last year. They said there was no oil in the oil pan??? Wasn't burning OR leaking oil....figure that one out? I still do not have any answers and it cost me $3500 to put in a new engine that had 35,000 miles. This engine also seems slower than the old. Good luck! My knock started in the head and within 15 minutes or so moved into the crank as well. Sounded identical to that. It would knock at low rpm, calm down a little bit when the rpm go higher, then started again.I keep meaning to contact GM to see if they had any solution as to why it happened but i keep forgetting.
