emergency brake light
Posted: Tue Oct 14, 2008 1:05 am
by smsteriti
I have a 2008 manual 5 speed Vibe. Does this model have a light that tells me that my emergency brake is set? is mine broken?
Re: emergency brake light (smsteriti)
Posted: Tue Oct 14, 2008 1:13 am
by DarkSpork
Yes.
Re: emergency brake light (DarkSpork)
Posted: Tue Oct 14, 2008 1:30 am
by smsteriti
Thank you, I've been finding that my brake has been engaged but no light telling me so. I didn't drive far before i realized it was on but now it's happened a few times and wanted to check before i took the time to bring it in to the shop.
Posted: Tue Oct 14, 2008 1:47 am
by DarkSpork
I hope it doesn't cost you a lot to get it fixed in a shop. I'm so cheap if I couldn't figure out how to fix it I'd just deal with it. EDIT: Is your emergency brake pulled up all the way? My dummy light for the emergency brake does not illuminate until its about half way up.
Posted: Tue Oct 14, 2008 4:00 am
by smsteriti
no, the light does not come on at all. it still under warrenty so i hope it doesn't take all day to get fixed
Posted: Tue Oct 14, 2008 4:22 am
by DarkSpork
It shouldn't.
Posted: Tue Oct 14, 2008 5:01 am
by ColonelPanic
Does the light come on when the key is turned to start? If it does come on, you just have a faulty switch on the brake lever or a bad connection. If it doesn't come on, thats a much bigger problem - could even be the gauge cluster itself then.
Posted: Tue Oct 14, 2008 9:49 am
by zionzr2
mine comes on just at first click as you are pulling it up.
