Bad header gasket?
Posted: Thu Oct 09, 2008 11:41 pm
by Petrucci914
Yes, I know, I'm the Gasket King lately. Should NOT have re-used most of the gaskets like I did.Anyways........replaced the Supercharger gasket, and got the tensioner replaced. Now I have even a higher whistle upon accelerating, even when I'm parked and I rev it. It's also been idling a bit worse lately.Thoughts? Would a bad header gasket cause all of that? I'm thinking it would have to be exhaust.
Posted: Thu Oct 09, 2008 11:44 pm
by northvibe
those metal gaskets should be reusable. is this the donut gasket on the header or the flat one from the header to the engine block?
Re: (northvibe)
Posted: Thu Oct 09, 2008 11:46 pm
by Petrucci914
Both
Re: (Petrucci914)
Posted: Fri Oct 10, 2008 11:09 am
by THE VIBERATOR
Check anything that could have a gap.Header, throttle body, intake, exhaust manifold, really anything that is connected. I have a rough idle problem and it's because of a vacuum leak in my throttle body, right where the spacer is. I can't fix it and it's not throwing a CEL so i dont mind, but it does act up from time to time.
