Code P2716, Auto trans not shifting good
Posted: Sun Oct 05, 2008 8:02 am
by hammerdown
I come here when I am looking for info so I thought I would pass this on. My check engine light came on and the transmission was not shifting right, very jerky not smooth. I did a search on google and this site was referenced with some post mentioning the error P2716 and the possibility of a bad pressure control solinoid in the transmission. Well I knew I was not covered under warranty (2006 Vibe 78k) but I decided to take it to the pontiac dealership. They scanned it and yes it did have the code P2716 and the tech found a service bulletin (41554a) that said if this code shows up replace the PCM module which is covered under a 100k or 8year fed warranty, at least thats what they told me. So they replaced the module and in 30 minutes I was back on the road and not a dime out of my pocket. Just thought I would pass this on.
Re: Code P2716, Auto trans not shifting good (hammerdown)
Posted: Sun Oct 05, 2008 11:11 am
by ramenboy...
hey glad the site helped and welcome to the family!!post pics of the vibe
Re: Code P2716, Auto trans not shifting good (ramenboy...)
Posted: Sun Oct 05, 2008 9:32 pm
by hammerdown
I looked thru my warranty manual and it appears it is a 80k warranty,, whewww I dodged a bullet on that one!
Posted: Thu Oct 09, 2008 9:11 am
by Lancer
I got a P0770 cel now and it jumps out of gear EVERY time I give it just a little gas. It's only been 2 years since the last tranny rebuild and was running perfect just befor the new engine was installed. Ever since the new engine went in, the tranny runs like crap?Thanks for the info, though! I'd like to try that, but the dealerships don't want anything to do with my car. Not much is stock anymore .
Posted: Tue Oct 28, 2008 4:56 am
by 02csnow
Got the same code today (P2716). And they told me I needed a new PCM. So it is getting dropped of at the dealership tonight.New PCM free of charge ( 80k warranty )
Posted: Mon Nov 24, 2008 8:34 am
by kstigler
I have an '05 Vibe with 54,000 miles on it. It threw a CEL and started shifting funny as well. I took it to AutoZone to have the code scanned, and they read a P2716. They cleared it and the car shifted fine. About an hour later the CEL popped up and it started shifting funky again. Took it to a Pontiac dealer this afternoon, the scanned it and read the P2716. The said that the PCM was the issue and that the car was covered under an 8 year 80,000 mile warranty from the factory. PCM was replaced, no money out of my pocket, problem solved! Yippee!
Re: Code P2716, Auto trans not shifting good (kstigler)
Posted: Mon Nov 24, 2008 8:48 am
by keithvibe
nice
Posted: Mon Dec 01, 2008 2:55 am
by statsia
Please help me out here, I have a 2003 and it it doing the same thing my husband is a mechanic and we coded it also a p2716 however after reading your posting I am reluctant to buy the solenoid if it is the PCM module as you said you tech found a bullentin and repaired yours under that. I called my local dealership and gave them the bullentin number and they cannot find it. Is if possible for your tech to email me a copy of that bullentin or provide the gm bullentin number to me so I can research this further.
Re: Code P2716, Auto trans not shifting good (statsia)
Posted: Sun Dec 14, 2008 6:28 am
by Paul92o
Having the same problem with a 2006 with 55k miles. I am also having trouble finding information on the service bulletin. Also, is the repair only covered if you have some sort of extended warranty. Any help is appreciated. Thanks.
Posted: Wed May 06, 2009 7:55 am
by rangita
I'm taking my Vibe in for service on this tomorrow. I wasn't able to find the service bulletin with the number given, but I tracked it down by hand. I only found it for the Matrix.NHTSA Item Number: 10020487Toyota Service Bulletin Number: 01406Summary: "HARSH SHIFT AND MIL ON DTC P2716."Links:http://www.allworldauto.com/ts....htmlh ... .ATRIX/You can also find it by searching the NHTSA page with the NHTSA number: http://www-odi.nhtsa.dot.gov/tsbs/tsbsearch.cfm
Posted: Thu May 07, 2009 6:37 am
by rangita
I just got back and the PCM was replaced for free under the 8-year warranty! If I hadn't found this forum & post, I probably would have paid a sack of money to my regular mechanic. Thanks, Generation Vibe!
Posted: Tue Aug 11, 2009 6:10 am
by piznarish
So, the check engine light came on and I took it to AutoZone to get a free diagnostic on it. And I got the P2716 code. I took to the stealership for repair...Man oh man... I fought my local stealership to get this covered under this warranty for 2 days! The stealership first quoted $650 to get this fixed. The service rep contacted their Pontiac rep to find out more. I provided the service rep w/ all these #'s (codes, document #s, id's, etc.). After a couple of days to wait for the part to arrive, the service rep said that it wasn't going to be covered under GM's warranty (3yr/36k), but he would knock off $50. I told him that about this forum and others forums, in which all the cases everyone was getting this covered under a 8yr/80k. I said, I need to research some more and get back to him. Get this --no more than 10 minutes after hanging up, the guy called back to say that it WOULD be covered under the warrenty after all and my car would be ready in 2 hrs -- it would just take more paper work!!! Can you believe that?! Anyway, I would like to thank you all for your information otherwise, I would have blindly forked over my $650! THANK YOU!!!I wonder if my situation is a product of the GM bankruptcy, the Pontiac brand being eliminated, and CARS program getting this GM stealership in a bind...
Posted: Sat Sep 12, 2009 5:28 am
by shbwaldrop@yahoo.com
Thank you very much for posting this information. It is very helpful.
Re: Code P2716, Auto trans not shifting good (shbwaldrop@yahoo.com)
Posted: Wed Oct 14, 2009 2:20 am
by jojuco
Would like to confirm above Vibe posts about p2716 code, had a check engine lite associated with hard shift between 1st and 2nd. Brought vehicle to a repair shop they told me it was the press. control solenoid that faulted and with labor 660 bucks for replacement of that part.. came home saw this web site, then went to Pontiac dealer and it was actually the PCM that was Bad. No charge even though it was out of warranty due to the bulletin: Document ID: 2081958 #PIP4154A Thanks! ....... knowledge is Power
Re: Code P2716, Auto trans not shifting good (jojuco)
Posted: Sat Apr 03, 2010 3:23 am
by jaimedc0
I love you guys. I am going to the dealer ship this monday. Hopefully this information will come in handy.
Re: Code P2716, Auto trans not shifting good (jaimedc0)
Posted: Sat Apr 03, 2010 9:28 pm
by jkm311
Quote, originally posted by jaimedc0 »I love you guys. I am going to the dealer ship this monday. Hopefully this information will come in handy. Glad the site helped you all out. And I'm glad you only experienced hard shifting. I stalled out at 50 MPH! And for all of you 1-posters, don't be a stranger! This community is a great place to frequent.
Posted: Wed Oct 06, 2010 12:30 am
by statsia
FINALLY I RECEIVED A RECALL IN THE MAIL FOR THIS PCM MODULE> MINE WAS NOT COVERED WHEN IT GAVE ME PROBLEMS BECAUSE I WAS OVER 80K. NOW I CAN GET IT FIXED!
Posted: Wed Dec 22, 2010 5:19 am
by AZVibe
Great information. I brought my 2006 Vibe in to the dealership this morning along with the codes and documents. PCM replaced under warranty.
