Tire pressure sensor reset... what am I doing wrong???
Posted: Sat Oct 04, 2008 10:33 am
by Bikerscum
A week after I got my '09 GT, I reset the TP monitor, just for something to do. Worked first time, no problems. I've since increased the air pressure & want to reset it again. I swear I've tried 20 times & it just won't work. What am I doing wrong? Anyone else have the same issue? Thanks
Re: Tire pressure sensor reset... what am I doing wrong??? (Bikerscum)
Posted: Sat Oct 04, 2008 10:49 am
by ehoff121
need more info, please.why don't you think the reset is working? does the light keep coming on?
Re: Tire pressure sensor reset... what am I doing wrong??? (ehoff121)
Posted: Sun Oct 05, 2008 4:07 am
by Bikerscum
The manual says that if the indicator light doesn't blink three times when holding the button down after a reset, the reset wasn't successful. I gots no blinks.
Posted: Sun Oct 05, 2008 5:32 am
by ou.grizzly
Is there any indications that the spare tire has a sensor in it?
Re: (ou.grizzly)
Posted: Tue Oct 28, 2008 2:02 am
by 2009GT
I cant get my light to go out either, any help on this? I have followed the manual.
Re: (ou.grizzly)
Posted: Tue Oct 28, 2008 2:16 am
by NibCrom
Quote, originally posted by ou.grizzly »Is there any indications that the spare tire has a sensor in it? That probably doesn't matter. The tire senses pressure by rotation. If the wheels are rotating at a different speed, it suspects one is low.Be sure to put all of your tires to the correct pressure before resetting the system. I'm not sure how to reset it on the 09's though. On my Alero I had to hold the switch until it blinked and then release and press again or something. I just messed with it for a few minutes until the light went off.
Re: (NibCrom)
Posted: Fri Nov 21, 2008 5:42 am
by jerzVibe09
Quote, originally posted by NibCrom »That probably doesn't matter. The tire senses pressure by rotation. If the wheels are rotating at a different speed, it suspects one is low.I'm not sure that's true, my tire pressure sensor went off when standing still and filling the tire to the proper inflation. Also this wouldn't make sense when the tires are slipping, as you would trigger the inflation sensor. I've replaced one of these before, I believe they work on actual pressure.
Re: (jerzVibe09)
Posted: Fri Nov 21, 2008 5:47 am
by NibCrom
I could be very well be wrong. My Olds Alero had tire pressure sensors and that is how they worked. And, like you said, I would get false readings on occasion. On long patches of rough road the light would come on. I would check the pressures and they would all be fine. That particular sensor did not measure actual pressure.
Posted: Fri Nov 21, 2008 6:05 am
by Truckin1999
Up till 08 they are based on rotation speed, not actual pressure. They may have changed that for 09 I have no idea. I thought I read on the boards here for the older Vibes you have to be driving and hit the button and not slow down for a certain number of miles.
