FUSEBOX %^*(&&&*(*&(@(&&^&
Posted: Fri Sep 26, 2008 6:48 am
by pingber
ok ... I give up, I've hired a contortionist (she was cute), a midget, etc etc ... how the &^%& does that fusebox open????? I can;t believe its location ... that's alot of confidence on the part of Pontiac that a fuse won;t blow out ... HELP (LOL) PS --- might it be easier to remove the dashboard lower panel?????? How hard is that????I'm ready to cut a hole in that panel and install a cover so I can get to the fuse panel in the future.
Re: FUSEBOX %^*(&&&*(*&(@(&&^& (pingber)
Posted: Fri Sep 26, 2008 6:55 am
by BlueCrush
Hahaha! There is a little tab at the front of the fuse box. Just push it in and pull up. lol EDIT: Oh, wait, the inside fuse box....hahahhaha...nevermind
by hskater26
i just layed on my back with my head near the peddles.....stuck a flashlight in my mouth and just unclipped the side that has the latch an it comes right off... i thought it was reasonably easy lol
Re: FUSEBOX %^*(&&&*(*&(@(&&^& (hskater26)
Posted: Fri Sep 26, 2008 7:03 am
by pingber
ok, I'm an idiot , so I'm on my back, looking up at this thing ... can you give me some orientation as to where this release tab might be? pedal side, window side, seat side, cneter console side? I just can't see it ... if anyone has a photo, it would be helpful.My back will never be the same after this ... its not a pretty position for a 58 year old to be in ....
Posted: Fri Sep 26, 2008 8:25 am
by hskater26
haha letme go out to my car hold on
Posted: Fri Sep 26, 2008 8:40 am
by hskater26
here you go....if your on your back looking up at it.....the release clip is right there on the side closer to you
Posted: Fri Sep 26, 2008 8:52 am
by pingber
Thanks a bunch .... and my chiropractor is sending a thank you basket of fruit to those great engineers at Pontiac.
Re: (pingber)
Posted: Fri Sep 26, 2008 9:21 am
by hskater26
(removed) no prob
Posted: Fri Sep 26, 2008 10:06 am
by northvibe
HAHHA (removed). I love seeing threads like this!!! so much help and so quick thanks hskater26 :D
Re: (northvibe)
Posted: Fri Sep 26, 2008 11:52 am
Quote, originally posted by northvibe »HAHHA (removed). I love seeing threads like this!!! so much help and so quick thanks hskater26 :DThat's the best part of genvibe to hskater26I would have looked at mine, but I have cursed that fusebox location enough in the past, no good intentions were going to get me to run out and check. pingber, what fuse do you think you blew, what doesn't work?and you can probably thank the engineers at Toyota for that location
Posted: Fri Sep 26, 2008 12:01 pm
by zionzr2
first prise goes to the engineres that put the oil filter above the exahust manifold and cat and below the computer on the Cavaliers. Possibly the worst design location for an oil filter I have ever seen.
Posted: Fri Sep 26, 2008 8:02 pm
by pingber
Well it turned out NOT to be the blower fuse .... the blower wasn't working ...its died before after I parked the car and it rained or was very hot. This time, I tapped the blower housing under the dash a few times and it started up again ... any ideas? Loose connection somewhere? I don't think its the resistor pack since that would eliminate the low speeds on the switch. I don't think its the motor brushes since that's either working or burnt out.
