Pop Ups
Posted: Sat Apr 19, 2003 5:56 am
by Vibegrrrl
I have not been a member here for very long, however shortly after becoming a member here I started to receive "pop ups". The "pop ups" come up on a grey window with plain text...usually asking me to watch someone strip or get off. It is always pornographic in nature. I usually just ignore it, cause whatever it doesn't usually bother me I am not a prude, but I don't need the computer screen to get stimulated. Anyway...I do spend a considerable amount of time on the net searching journal material as I am working on my Master's Degree but I only receive the "pop ups" while I am on the Vibe Forum. My question is...does anyone else get the "pop ups" and could it be from a member here?
Re: Pop Ups (Vibegrrrl)
Posted: Sat Apr 19, 2003 6:13 am
by rasermon
Good afternoon.Download this software to remove spy-ware from your pc, also delete your cookies.
http://download.com.com/3000-2144-10186 ... ag=lst-0-3 1.45MB Ad-aware
Re: Pop Ups (rasermon)
Posted: Sat Apr 19, 2003 6:17 am
by Vibegrrrl
Thanks Rasermon...much appreciated!!
Posted: Sat Apr 19, 2003 8:06 am
by rasermon
Anytime! Ad-aware should clean it up. If you run into problems IM me.
Posted: Sat Apr 19, 2003 9:27 am
by Keely
You may also want to look into browser alternatives that block pop-ups. I've been using a freeware IE add-on called Avant Browser
http://www.avantbrowser.com/. It has a pop-up blocker that you can toggle on and off with the click of a button, which is handy when you want to have an IM session with a fellow GenViber (the IM box is interpreted as a pop-up window and therefore blocked from appearing at all). In addition, it has a great MDI functions (many pages appearing as tabs in a single Avant window rather than having many windows open) and lots of other cool features. Although it is a bit of a resource hog, you can't beat the price. Hope that helps!
Re: Pop Ups (Keely)
Posted: Sat Apr 19, 2003 9:55 am
by Geo
Mozilla is also a good browser out there that can automatically block all incoming popups.
http://www.mozilla.orgI personally use Safari, before that Mozilla and Chimera (now known as Camino), yes I am also a Mac user (w00t!), and using browser-integrated popup blocking, I have not seen an unrequested popup in well over a year - if not longer. Browsing is so nice now
Posted: Sat Apr 19, 2003 10:39 am
by KSNeptune
If you are using window's XP ir NT or 2000, you may be a victim of the exploited "messaging" feature. It was intended to let sysop managers send employees hooked into an office network messages like "The network server will be shut down in 5 minutes. Please save all you work now."If you are NOT in an office using the offices computer, then you can disable this "feature". Tell me what operating system you are running and if it's XP I'll tell you how to turn it off.KSNeptune
Re: Pop Ups (KSNeptune)
Posted: Sat Apr 19, 2003 9:38 pm
by coratz
what if you use kazza like me? if i stuck with that save now pop up crap?
Posted: Sat Apr 19, 2003 11:51 pm
by cohocarl
Doesn't sound right. I have never had a "pop-up" on this forum and I'm running Win xp, 2000 and ME, with I.E. I'd try Rasermon's recommendation on deleting cookies if you haven't, and run AdAware. Keep us informed if it still does it or not.
Re: Pop Ups (cohocarl)
Posted: Sun Apr 20, 2003 12:03 am
by esjones
quote:Doesn't sound right. I have never had a "pop-up" on this forum and I'm running Win xp, 2000 and ME, with I.E.Same here (Win 2000 Pro). I have a bookmark, though, that takes me directly to the fora, bypassing the main page.
Posted: Sun Apr 20, 2003 12:05 am
by d_m_kolb
This is the first I have heard of this. genvibe.com doesn't use pop up of any kind for advertising. Also we wouldn't allow porn advertising of any kind on this site in the first place. We do use the instant messaging system but that's different.Does this only happen on genvibe.com or on ever website you visit?
Posted: Sun Apr 20, 2003 1:58 am
by Vibegrrrl
Hey KSNeptune,I am using XP, thanks for the assist.Thanks to everyone for their input. Much Thanks!!
Re: Pop Ups (Admin II)
Posted: Sun Apr 20, 2003 2:01 am
by Vibegrrrl
Only when I am on Genvibe. My partner is also on the net alot, never here, and has not had the same popups. It could be coincidence...you tell me.
Posted: Sun Apr 20, 2003 2:18 am
by rasermon
quote:Only when I am on Genvibe.I'm also having problems with genvibe, just when viewing the forums.No pop-ups, but not all images will load. When I'm not logged in its fine. Corrupt cookies
Re: Pop Ups (silverawd26)
Posted: Sun Apr 20, 2003 4:03 am
by mu_ohio
Netscape also has built in pop up protect and it seems to work very well. Currently I'm using Safari on my PowerBook, but it seems to be a lot like Netscape. I actually think they are built on the same engine. I would turn on WinXP's firewall since it will prevent spam messages from Window's Messenger, or at least in my experience.
Re: Pop Ups
Posted: Sun Apr 20, 2003 4:58 am
by NSimkins
quote:Only when I am on Genvibe.I'm also having problems with genvibe, just when viewing the forums.No pop-ups, but not all images will load. When I'm not logged in its fine. Corrupt cookies Very interesting indeed, but you are not alone. I noticed the same 'issue' on the forums as well. This was predominately worse when most of the forum images were being pulled in from zeroforum.com rather than genvibe.com's own server. This means, when zeroforum.com's server was experiencing slowness or difficulties, the forum would never completely load up the page and prevent IM's and other features from operating properly.I recently moved all forum images over to the genvibe server and personally have noticed much better performance, but not completely. For example, older posts that still reference zeroforum.com's server in their images may still experience slowness depending on their server's status. Gradually, that should work itself out of the forum threads.Another point to note as well, I ran Windows Update on my XP box (10 updates in 2 months, no surprise ) and noticed IE performance was improved.However, there are a couple patches out there that will actually worsen IE/Windows performance. Thanks to rasermon for pointing out this link:
http://www.broadbandreports.com/forum/r ... latAnother note, as Admin II stated, we do not utilize pop-up advertisements on GenVibe, except for the IM pop-ups. In many cases, installed programs like Kazaa and other ad-ware based programs will cause random pop-ups when launching IE. Use the advice given above from other members on how to alleviate this problem. Now, things may change on the site without Admin II or myself knowing.... it happens, but we try to stay on top of things that will affect site performance.As always, please feel free to IM or e-mail me if you experience ANY forum problems.
Posted: Sun Apr 20, 2003 7:54 am
by esjones
quote:What does corrupt cookies mean? And do not try to pull a fast one by telling me it has something to do with a Kebler Elf or The Cookie Monster... LOL. Serious, I do not even know what cookies are Cookies are small files that a web site can store on your computer, and then ask for later, and your browser will send it back. They are used to identify and track you. It is how GenVibe recognizes you when you come back, for example.
Re: Pop Ups (NSimkins)
Posted: Sun Apr 20, 2003 10:29 am
by Stang2Vibe
quote:the forum would never completely load up the page and prevent IM's and other features from operating properly.I was experiencing this very frequently within the past 2 weeks. I was worried that it was my internet connection.I also use Kazaa and hate those stupid "Save Now" popups that plague my surfing experiences. Maybe I will have to try one of these popup blocking programs.
Re: Pop Ups (Stang2Vibe)
Posted: Sun Apr 20, 2003 10:43 am
by rasermon
quote:I was experiencing this very frequently within the past 2 weeks. I was worried that it was my internet connection.I just did a clean install XP home with the same problem viewing genvibe forums. I'm sure this is a problem with the server zeroforum.
Posted: Sun Apr 20, 2003 12:36 pm
by KSNeptune
VibegrrlGo to STARTRUNenter "services.msc", then click OKFind MESSENGER in the list on the right panelRight click on it, select PROPERTIES.On the GENERAL tab, about half way down, change Startup Type to "DISABLED"That will disable the messenger "feature", and if it is where your pop-ups were coming from they should stop next time you've rebooted and then gotten on the web.Good luckKSNeptune
Re: Pop Ups (joatmon)
Posted: Mon Apr 21, 2003 2:35 am
by millster
You might want to check in your profile and make sure your e-mail address is not being displayed on the site (in fact, a quick peek at your profile shows it is being displayed). You can turn this off in your My Profile section. There are crawlers out there searching for visible e-mail addresses on webpages and spamming them if found. If you do want people to be able to e-mail you, just sign up for a free web-based e-mail address. When I signed up, I just used an already spam laden Hotmail account.
Posted: Mon Apr 21, 2003 1:44 pm
by Vibegrrrl
Thanks KS!!
Posted: Mon Apr 21, 2003 11:13 pm
by Big_Red
Personally, I have never had this problem while on this site, but I do feel the pain when I go elsewhere.
Posted: Tue Apr 22, 2003 10:48 am
by KSNeptune
quote:Thanks KS!! You are quite welcome. Let me know if my advice worked.KSNeptune
