manually turning off headlamps at night
Posted: Fri Sep 19, 2008 9:21 am
by Ojibway Princess
Hello,I have a 2007 Vibe and wonder how I can manually turn off my headlamps with the engine running. My problem is that I have to take a car ferry home at night. The operator of the ferry wants the headlamps off while driving on and off the ferry so the crew does not loose their night vison. One can get a ticket for this if this rule was enforced. Any ideas?Thank you,Ojibway Princess
Re: manually turning off headlamps at night (Ojibway Princess)
Posted: Fri Sep 19, 2008 9:29 am
by keithvibe
only way to do that is to disable your Auto light feature. you can cut pin 12 on the DRL module. In doing so you will lose your auto lights and your DRL lights.Wire in a switch to that wire and then you can turn on and off the auto light feature at your leasure and the drls as well
Re: manually turning off headlamps at night (keithvibe)
Posted: Fri Sep 19, 2008 9:39 am
by Ojibway Princess
thank you keithvibe,I appreciate your quick response. I shall certainly look into this as soon as possible.Ojibway Princess
Posted: Fri Sep 19, 2008 9:52 am
by jake75
Considering the fact that all GM cars for the past several years have these automatic headlights I doubt that this "law" would or could be enforced.I suppose one could tape some blinders on the headlights while waiting in line to drive on.
Re: manually turning off headlamps at night (jake75)
Posted: Fri Sep 19, 2008 10:17 am
by keithvibe
or simply wire in a switch and a flick of the finger can turn them on and off with ease... instead of getting out of the car and taping the headlights or covering them up with somethingdo a search for drl mod. it's stickied in the do-it yourself threads
Posted: Sat Sep 20, 2008 5:41 am
Quote, originally posted by jake75 »Considering the fact that all GM cars for the past several years have these automatic headlights I doubt that this "law" would or could be enforced.I suppose one could tape some blinders on the headlights while waiting in line to drive on.True, but I think most "true" GM's have the ability to disable auto lights for the duration of the ignition cycle. I know my 6 does, and I was under the impression many models did for several years back.
Posted: Sun Sep 21, 2008 12:55 am
by Vibe_dude
Click the hand brake 1 notch...it should disable it.Use to do it on my buddies 90 something camero and if I start my montana with the e brake on the lights dont come on till I take the brake off.
