1zz+SC+Crank Pulley=?
Posted: Wed Sep 17, 2008 11:04 pm
by 4azdmunky
Hey everyoneLooking for some guidance. When I installed the SC I pulled off the OBX crank pulley and put back on the stock one. I understand that the 2zz’s have problems with aftermarket pulleys and the oil pumps. Would a boosted 1zz have the same problems? Would there be any benefit to putting the aftermarket pulley back on along with the SC?Thanks!
Re: 1zz+SC+Crank Pulley=? (4azdmunky)
Posted: Wed Sep 17, 2008 11:09 pm
by BlueCrush
Vibe Freak has an Alutec OEM sized lightweight crank pulley install on his set-up. I wouldn't recommend underdrive pulleys for either N/A or F/I applications. I will only recommend OEM sized lightweight pulleys. If you did choose to put your OBX underdrive pulley on you would need to guess at the belt size you would need. I don't know of anyone who has the S/C with an underdrive pulley.
Re: 1zz+SC+Crank Pulley=? (BlueCrush)
Posted: Wed Sep 17, 2008 11:24 pm
by 4azdmunky
Yeah i was was not able to find anyone with a underdrive pulley on a boosted 1zz either. I'll look at going to a lighter pulley then.
Posted: Wed Sep 17, 2008 11:26 pm
by BlueCrush
Quote, originally posted by 4azdmunky »Yeah i was was not able to find anyone with a underdrive pulley on a boosted 1zz either. I'll look at going to a lighter pulley then.Alutec is the only OEM lightweight crank pulley on the market and you can only get it here:
http://www.motorexonline.com/crankpulleys.html
Posted: Thu Sep 18, 2008 11:14 am
by 4azdmunky
Hey BlueCrush I noticed that you were selling a alutec and a alternator pulley earlier this year. Did those ever sell?
Posted: Thu Sep 18, 2008 11:22 am
by BlueCrush
No they are still on my vibe and that is where they are staying...lol
Posted: Thu Sep 18, 2008 10:52 pm
by 4azdmunky
LOL good
Posted: Fri Sep 19, 2008 12:39 pm
by vibe Freak
The OEM Size pulley works fine, I would not run a under drive pulley on a S/C 1zz. You will under drive the S/C and make only 4 to 5 pounds of boost. The after market pulley was put on the same time as the blower ,
Re: (vibe Freak)
Posted: Mon Sep 22, 2008 10:37 am
by 4azdmunky
I put the orginal pulley on when I put the SC on about a year ago. The odd thing is i'm only getting 5.5 pounds of boost max. The analog gauges (Meghan) were showing between 6-10. I just repalced them with PLX gauges,and that boost gauge shows 5.5.
