Practicality/ Need for "L" brackets on '09 Vibe
Posted: Wed Sep 10, 2008 3:38 am
by alphafelix
I have some sort of "L" bracket in front of my front tires and not sure what the practical use is for them. Curb stopper? (see attached)Does anyone know or has anyone removed them?
Posted: Wed Sep 10, 2008 3:51 am
by ss21
Can't really see it in the picture....I think its a toyota thing...my Camry & Corolla both have them...but I'm not quite sure what its purpose is.
Re: (ss21)
Posted: Wed Sep 10, 2008 3:52 am
by kevera
Is there anyway you can lighten up that pic a touch.
Re: (kevera)
Posted: Wed Sep 10, 2008 4:13 am
by bull77
not the best edit job b/c i'm at workits the small plastic piece in front to the front tires --- have to have the right angle or get under to see it
Re: (bull77)
Posted: Wed Sep 10, 2008 4:15 am
by kevera
Isn't that a little splash shield.
Re: (kevera)
Posted: Wed Sep 10, 2008 4:17 am
by bull77
Quote, originally posted by kevera »Isn't that a little splash shield.thats what i think
Posted: Wed Sep 10, 2008 4:23 am
by kowell
Here is a better shot.I was wondering also what it was.... I always considered it as the weakest front mudflap ever.
Posted: Wed Sep 10, 2008 4:37 am
by alphafelix
At first I thought that too, but the mud flap would be behind the tire. I'm just hoping it isn't something the factory was suppose to remove before sending it out.
Posted: Wed Sep 10, 2008 4:55 am
by Sublimewind
Those catch the roadkill when you don't swerve fast enough... lol..
Posted: Wed Sep 10, 2008 5:20 am
by zionzr2
Those are to direct airflow and help with aerodynamics and fuel economy.They usually help direct air around the tires so the have less drag. they also help direct cooler air into the engine bay.
Re: (zionzr2)
Posted: Wed Sep 10, 2008 5:47 am
by kevera
Quote, originally posted by zionzr2 »Those are to direct airflow and help with aerodynamics and fuel economy.That sounds like a possibility.Quote, originally posted by zionzr2 »they also help direct cooler air into the engine bay.I don't see that though,not with the placement of them.Quote, originally posted by Sublimewind »Those catch the roadkill when you don't swerve fast enough... lol.. ahahaha,I think this is why.
Re: Practicality/ Need for "L" brackets on '09 Vibe (alphafelix)
Posted: Thu Sep 11, 2008 12:59 am
by Toasted7
I don't ever remember seeing a Vibe that didn't have these. I had my theories about them too, just never really asked I guess.
Posted: Fri Sep 26, 2008 3:30 am
by tribalman
Quote, originally posted by alphafelix »Does anyone know or has anyone removed them?i have removed them, but i put it back on. from what i figure it to be is an air flow diverter or something like that. if that's what it is then it is designed to cause a bit of turbulence under the car creating a bit of suction to lower the car. as for removing them all you need is a wrench and the socket. just undo the 2 bolts and it'll come right off. there isn't a nut on the other side so you don't need to remove the liner to get that thing off
Posted: Sun Sep 28, 2008 11:00 am
by MountainMax
I broke mine off, dirt roads, lol
Re: (MountainMax)
Posted: Sun Sep 28, 2008 1:31 pm
by NascarXprt
i took mine off the first time i took off my front bumber. Quote, originally posted by Toasted7 »I don't ever remember seeing a Vibe that didn't have these. I had my theories about them too, just never really asked I guess.same here.
Posted: Mon Sep 29, 2008 2:37 am
by alphafelix
By taking them off, do you notice any difference in gas mileage? I am really considering removing mine as well.
