Disable Annoying Seat Belt Buzzer
Posted: Thu Sep 04, 2008 3:24 am
by MigAZ
New Vibe owner/member here and wanted to say you have an excellent site here!I'm sure you all are familiar with the seat belt buzzer issue. For those of you that disabled it, what did you do?Thanks and looking forward to contributing!
Re: Disable Annoying Seat Belt Buzzer (MigAZ)
Posted: Thu Sep 04, 2008 3:46 am
by rAERRK
new indeed. i recommend getting familiar with the search button.
http://forums.genvibe.com/zerothread?id=18678
Posted: Thu Sep 04, 2008 4:24 am
by 808 Vibes
Welcome and congrats!
Re: Disable Annoying Seat Belt Buzzer (rAERRK)
Posted: Thu Sep 04, 2008 4:34 am
by MigAZ
Searched and solved! Thanks.
Posted: Thu Sep 04, 2008 4:52 am
by willysr
Is your vibe an 09 and if so how did you stop that annoying seat belt beep?any help on this would really be appreciated.
Re: (willysr)
Posted: Thu Sep 04, 2008 4:55 am
by MigAZ
Quote, originally posted by willysr »Is your vibe an 09 and if so how did you stop that annoying seat belt beep?any help on this would really be appreciated.No, mine is an '05. Sorry.
Re: (willysr)
Posted: Thu Sep 04, 2008 5:00 am
by engineertwin2
You could always find the buzzer and use a jumper to wire around it...or cut it out altogether.
Re: (engineertwin2)
Posted: Thu Sep 04, 2008 11:54 am
by scott_h
Quote, originally posted by engineertwin2 »You could always find the buzzer and use a jumper to wire around it...or cut it out altogether.Or wear your seatbelt?
Re: (scott_h)
Posted: Thu Sep 04, 2008 12:12 pm
by DarkVibe
Quote, originally posted by scott_h »Or wear your seatbelt? oh, i like that idea.
Posted: Fri Sep 05, 2008 5:44 am
by fast_monte
You can't just use a jumper wire, It will mess with the air bag system. I used a jumper wire on the passenger seat and the air bag light statys on. I did it because when I put the whitwater kayak in the car it pushed against the seat the the car thinks a person is in the passenger seat. Turning off the beeper with the secret code worked much better.
Posted: Sun Sep 07, 2008 3:01 am
by rated_w
take this from a guy who knowsWEAR UR SEATBELT! It saves lives, trust me, it saved my friend's life a few months ago..
Re:
Posted: Sun Sep 07, 2008 4:12 am
by moongdss
no one ever said they *weren't* wearing their seatbelt. Sheesh! Any of you ever try moving a bookcase or something else long that rests on the folded down passenger seat? Yeah, that beeping will drive you batty!! The seat belt beep mod was my very first (and most worthwhile) mod! I recommend keeping the code sequence in the glovebox or some other handy place because I'm told anytime you disconnect the battery you'll have to reprogram it.
Posted: Sun Sep 07, 2008 10:26 am
by shadow_dog
06 base Vibe sounded like the seat belt warning was on full volume. I hated that noise. My new 09 GT is nowhere near as loud as the 06, thank god.
Re: Re: (moongdss)
Posted: Sun Sep 07, 2008 12:27 pm
by MigAZ
Quote, originally posted by moongdss »no one ever said they *weren't* wearing their seatbelt. Sheesh! Any of you ever try moving a bookcase or something else long that rests on the folded down passenger seat? Yeah, that beeping will drive you batty!! The seat belt beep mod was my very first (and most worthwhile) mod! I recommend keeping the code sequence in the glovebox or some other handy place because I'm told anytime you disconnect the battery you'll have to reprogram it.Exactly! I wear it at all times; however, I have a habit of unfastening it at the mailbox and when I am arriving into my cul-de-sac. It is annoying in these short distances. Much better now, though!
Re: (fast_monte)
Posted: Sun Sep 07, 2008 10:28 pm
by jake75
Quote, originally posted by fast_monte »You can't just use a jumper wire, It will mess with the air bag system. I used a jumper wire on the passenger seat and the air bag light statys on. I did it because when I put the whitwater kayak in the car it pushed against the seat the the car thinks a person is in the passenger seat. Turning off the beeper with the secret code worked much better.Can't you just fasten the seatbelt? (with no one in the seat obvioulsy)
Re: (willysr)
Posted: Wed Sep 10, 2008 10:50 am
by mydogsowner
Wait out all the beeps. The annoying sound will stop! It took me a few ti figure it out as I always buckled up before it would quit.
