09 Vibe's Center Cap (Aluminum Wheel only)
Posted: Fri Aug 29, 2008 11:52 am
by tnpartsguy
They have released a service bulletin concerning the center caps falling off the '09 Vibes. 08-03-10-011: Loose orMissing Wheel Cap Repair Procedure - (Aug 22, 2008) The 'fix' is to glue the new ones in, which you MIGHT need to know when you go to get your tires rotated, since they will have to be reglued every time.
Re: 09 Vibe's Center Cap (tnpartsguy)
Posted: Fri Aug 29, 2008 12:12 pm
by imspace2
Geez I guess it just took me calling in every week since I've had the problem, but how do I get a dealership/GM to buy me a new set of caps?
Posted: Fri Aug 29, 2008 12:27 pm
by tnpartsguy
give them the Bulletin # I presented you..... just don't tell them where you got it...I'm on GM's bad list right now anyway.
Posted: Sat Aug 30, 2008 9:07 am
by scooter
Quote, originally posted by tnpartsguy »They have released a service bulletin concerning the center caps falling off the '09 Vibes. 08-03-10-011: Loose orMissing Wheel Cap Repair Procedure - (Aug 22, 2008) The 'fix' is to glue the new ones in, which you MIGHT need to know when you go to get your tires rotated, since they will have to be reglued every time. Why would these need to be re-glued? You don't need to remove to get to the lug nuts...?
Re: (tnpartsguy)
Posted: Sat Aug 30, 2008 9:17 am
by DarkVibe
Quote, originally posted by tnpartsguy »give them the Bulletin # I presented you..... just don't tell them where you got it...I'm on GM's bad list right now anyway.uh-oh, watch out for those black suburbans.
Re: 09 Vibe's Center Cap (scooter)
Posted: Sun Aug 31, 2008 10:25 pm
by tnpartsguy
Quote, originally posted by scooter »Why would these need to be re-glued? You don't need to remove to get to the lug nuts...?.........but you do have to remove them to balance the tires, or to mount new tires
Re: (DarkVibe)
Posted: Sun Aug 31, 2008 10:26 pm
by tnpartsguy
Quote, originally posted by DarkVibe »uh-oh, watch out for those black suburbans.Actually, in a GM dealership's case, it's a white 15 passenger van. That's what the audit team rolls in.
Posted: Mon Sep 01, 2008 3:19 am
by scooter
Quote, originally posted by tnpartsguy ».........but you do have to remove them to balance the tires, or to mount new tiresVery true.... hopefully they have a permanent fix by the time that's necessary....
Posted: Thu Sep 04, 2008 2:59 am
by Yanner
Lost 2 caps in about a week on a brand new 09 with the 17 inch wheels that come with the 1sc package. I might write my name/phone number on the back of the other two
Re: 09 Vibe's Center Cap (Yanner)
Posted: Thu Sep 04, 2008 5:24 am
by engineertwin2
Quote, originally posted by Yanner »Lost 2 caps in about a week on a brand new 09 with the 17 inch wheels that come with the 1sc package. I might write my name/phone number on the back of the other two I would love to return a hubcap like that...
Posted: Wed Apr 14, 2010 4:27 am
by thamster
Don't know why they need to remove them, but after I took mine in to the dealer to get the tires rotated (no balancing or mounting), ALL of them fell off after 2 weeks.The dealer is refusing to replace them under warranty even after I showed them the service bulletin, claiming it's not a warranty repair (even though the warranty labor code is on the bulletin itself). (removed)?
