Thinking of Seafoaming my Vibe...
Posted: Sun Aug 17, 2008 10:04 am
by BlueCrush
Anyone else tried this on their Vibe? If so, did you do all 3 steps (Intake (1/3 can), Fuel Tank (1/3 can) and crankcase (1/3 can prior to oil change). I was thinking of only doing the intake and fuel tank since I recently had my oil changed. Did you notice any benefits? (smoother engine, better acceleration, better mileage)?Thanks
Re: Thinking of Seafoaming my Vibe... (BlueCrush)
Posted: Sun Aug 17, 2008 11:14 pm
by djb383
I just use a good strong dose in the tank. As lean as modern EFI ECU controlled engines run, carbon build-up just isn't an issue. I also do frequent oil changes (synthetic) so sludge build-up is also not an issue.
Posted: Mon Aug 18, 2008 10:42 am
by jwalcik
I've never used it in my Vibe, but I did use it in an old motorcycle that had been sitting for a few years. I had a few nasty backfires with the first half tank of gas, but after that, the bike ran much better.
Re: Thinking of Seafoaming my Vibe... (jwalcik)
Posted: Thu Aug 21, 2008 10:23 am
by ProtonXX
I used to use Seafoam quite a bit, then I realized techron does the same thing. After some reading, i saw Seafoam doesnt have spectacular ingredients and about half of it is pale oil. I did the same seafoam steps but replaced it with a bottle of concentrate techron & got the white smoke effects also.But I got the best results by taking out the spark plugs and pouring techron right into the cylinders. Then I cranked the engine to let it slush around a bit for a few seconds, replaced the plugs & blew out some white smoke for 5 min.
Posted: Thu Aug 21, 2008 12:03 pm
by DarkVibe
i seafoamed my '99 cavalier you wouldn't believe all the crap that came out of the tail pipe. i put all of it in the intake.
Re: Thinking of Seafoaming my Vibe... (DarkVibe)
Posted: Thu Sep 11, 2008 2:21 am
by p8md
I've used SeaFoam on by wife's van. Everytime it starts knocking, I pour half a can of Seafoam in the gas tank and it goes away for 3-4 months.
