What wheels will fit (looking for winter rims)
Posted: Sun Aug 17, 2008 7:21 am
by Jeremy_K
Hey guys, I was just wondering if there's a list made up of wheels we can use on our vibes that also have the correct backspacing? I'm gonna be hitting up Craigslist looking for rims to slap snow tires on. I have the 16" factory rims on my Vibe and I'd like to get wheels that won't throw off the speedo/odometer. 15 or 16" it doesn't matter. Any recommended combinations that maintain the stock diameter? Thanks
Posted: Sun Aug 17, 2008 9:41 pm
by kowell
You can use the calculator from this link to see the speedo difference.
http://www.miata.net/garage/tirecalc.html
Re: What wheels will fit (Jeremy_K)
Posted: Sun Aug 17, 2008 9:52 pm
by keithvibe
15" corolla rims could be used with out issue.
Posted: Mon Aug 18, 2008 12:07 am
by Sublimewind
I know for a fact that my Subaru steel winter wheels fit... as long as the wheels are 5x100 bolt pattern and ~35 in offset you should be golden..
Posted: Mon Aug 18, 2008 10:45 am
by Ol' Timer
I'm running 15" steel rims and 195/65/15 Michelin X-Ice Snow Tires. It's debateable but I feel that they're better in the snow and they are less expensive than the OE size 205/55/16. The diameter is virtually the same as 205/55/16 tires so you're speedometer will register the same mph/kph/miles/km/whatever.Oh, and I got these rims off of my VW New Beetle.
Re: What wheels will fit (Ol' Timer)
Posted: Mon Aug 18, 2008 10:53 am
by Mavrik
standard 16" steels will do the trick.
Posted: Mon Aug 18, 2008 11:39 am
by B14CK_H4WK
i have 17in rims as long as the total diameter of the wheel with the tire mounted is the same as it was stock you wont have a problem with the gauge being off. bigger rim + less tire = same gauge read out smaller rim + more tire = the same idea. a few inches difference wont throw your gauge off too much any way
Re: (B14CK_H4WK)
Posted: Mon Aug 18, 2008 8:01 pm
by Raven
15" Corolla wheels with 195/65/15 tires are the way to go. The tires are a lot cheaper in that size and narrow and tall are better for snow.
Posted: Tue Aug 19, 2008 11:46 am
by Jeremy_K
I have a line on some chevy beretta rims that are 5 X 100. Should they work?
Re: (Jeremy_K)
Posted: Tue Aug 19, 2008 8:08 pm
by Raven
Check the offset. You may need hubcentric rings if the center bore is a different size but thet're only about $15.00.
Posted: Mon Sep 08, 2008 11:13 am
by Jeremy_K
That's a no go on the Beretta rims. They don't come close to fitting over the brake calipers. I now have 4 205/60/15 snow tires with no rims.
Posted: Mon Sep 08, 2008 11:10 pm
by Sublimewind
Find different rims... Suggestions were made, hit up a junkyard... gotta be a wrecked vibe or matrix with them somewhere.. or a subie, or a corrola
