Engine codes
Posted: Sun Aug 17, 2008 2:43 am
by CUV03
Anyone have info that shows engine codes and there meanings? Throwing 6 or 7 of them. When filling up the gas car almost stalled.
Re: Engine codes (CUV03)
Posted: Sun Aug 17, 2008 5:12 am
by Mavrik
most manufactures use the same codes... post up what your getting and I'll see what I can help with.
Re: Engine codes (Mavrik)
Posted: Tue Aug 19, 2008 11:37 am
by CUV03
I just got the codes checked again today and it is only throwing 4 now. Here they are: P0440, P0441, P0446, P0171.
Posted: Tue Aug 19, 2008 12:08 pm
by Petrucci914
Vacuum LeakBad MAF SensorDirty MAF SensorDid you recent install a Cold Air Intake and over-oil the filter?
by BlueCrush
Quote, originally posted by CUV03 »I just got the codes checked again today and it is only throwing 4 now. Here they are: P0440, P0441, P0446, P0171.Try these links:
http://www.obd-codes.com/p0440http://ww ... .com/p0171
Re: Engine codes (Petrucci914)
Posted: Thu Aug 21, 2008 5:58 am
by CUV03
No, same one I had in before I got any codes. Are all those codes related?
Re: Engine codes (BlueCrush)
Posted: Thu Aug 21, 2008 6:01 am
by CUV03
Links aren't working can you repost? Thanks.
Posted: Thu Aug 21, 2008 9:09 am
also
http://forums.genvibe.com/zerothread?id=10094the P044* ocould be the gas cap, 171 is a lean condition, that with the P044*, maybe a vacuum hose is off or cracked somewhere
Re: Engine codes (joatmon)
Posted: Fri Aug 22, 2008 10:38 am
by CUV03
One day while getting my tank filled my car almost stalled. (normally I shut off the engins) Does this indicate anything?
Posted: Fri Aug 22, 2008 10:44 am
by CUV03
Thanks for the link.
Posted: Wed Sep 03, 2008 9:48 am
by CUV03
After a repair is made do you have to get the check engine light reset?
Posted: Thu Sep 04, 2008 1:12 am
by engineertwin2
Typically, a service technician will reset the codes after they perform the repair, but often times, they clear the codes right after they read them. For a fuel filler cap issue, once corrected, it would reset the light after 3 driving cycles.Out of curiousity, what caused you to keep the car running while filling the tank? I don't know that I've ever seen anyone actually do it, but it doesn't seem like a good idea.
Re: (engineertwin2)
Posted: Fri Sep 05, 2008 7:16 am
by CUV03
Thanx for the info. Agreed, it's not a good idea. I was next in line at my usual gas station with my tank door open. While moving up to the pump the service attendent took the cap off and he started filling up my tank. Just at that moment the engine was trying to stall. I guess being that I frequent the same station they know what I get everytime. I told them they should wait until the car is stopped and off.
