hit lift, finally
Posted: Sun Aug 10, 2008 10:00 am
by bodhi_tree777
So for the most part, we drive like old folks to maximize the ol' fuel economy. However, today i was driving around minus the wife and child and got a wild hair to hit lift (owned the car for 8 months and haven't yet). Revved it up, let 'er rip, and she took off in fine style. Nice feature, although one I doubt I'll use much. It's fun and all, but most of the time I've got the family in the car or i'm on roads where there isn't really the room for it. So my question: is it good for the engine to crank it up every so often? I remember reading in Popular Mechanics that its not a bad thing to floor it every once in a while, to blow the crud out of the injectors or something along those lines. Is that true with the 2zz?
Re: hit lift, finally (bodhi_tree777)
Posted: Sun Aug 10, 2008 11:20 am
by coldmm803
8 months and you've just hit lift for the first time!!! thats like a sin. j/k no, it shouldn't be bad for the engine, engineers design the engines and they get tested for a lot of hours and redline is there for a reason just make sure to shift
Re: hit lift, finally (coldmm803)
Posted: Sun Aug 10, 2008 11:23 am
by kunkstyle
The only way you'll harm it is by over-revving it. But that's what a rev limiter is for.
Posted: Mon Aug 11, 2008 3:49 am
by Nelson
All right.... I'm dying to find out!What's LIFT?
Re: hit lift, finally (Nelson)
Posted: Mon Aug 11, 2008 4:01 am
by bull77
Quote, originally posted by Nelson »All right.... I'm dying to find out!What's LIFT?we don't have it in our base models, only the older GTs had it lift = more power at higher rpmhttp://forums.genvibe.com/zerothread?id=7522
Posted: Mon Aug 11, 2008 4:05 am
by northvibe
Lift is similar to honda's vtec kicking in. Like adding nitrus in at a specific rpm. i mean kinda not like it will have tons of torq but...The 2zz loves to rev, it will not hurt it at all, in fact, I hear a kitten dies every time you dont hit lift
Posted: Mon Aug 11, 2008 4:09 am
by breezd
Quote, originally posted by Nelson »All right.... I'm dying to find out!What's LIFT?Lift is a feature with the GT's, when you hit a certain RPM (6200rpm on the 03's, not sure what the other years are but it changed each year i believe), the engine has an extra "kick". It's a great thing to experience In my eyes, it's the thing that REALLY makes the GT stand out from the base model. I couldn't live without lift...
Re: hit lift, finally (breezd)
Posted: Mon Aug 11, 2008 4:12 am
by northvibe
Quote, originally posted by breezd »Lift is a feature with the GT's, when you hit a certain RPM (6200rpm on the 03's, not sure what the other years are but it changed each year i believe), the engine has an extra "kick". It's a great thing to experience In my eyes, it's the thing that REALLY makes the GT stand out from the base model. I couldn't live without lift...you could if you had boost
Posted: Mon Aug 11, 2008 4:21 am
by AKLGT
I test drove all 3 models back in 03. Only reason I bought the GT was because it was FASTER! Was a fun little car for sure...
Posted: Mon Aug 11, 2008 4:24 am
by engineertwin2
To be more technical here, lift is a second set of lobes on the camshaft that are activated hydraulically at a set rpm (6300+). Once the higher profile cam lobes are engaged, the valves open up more to allow more fuel and air to be dumped into the cylinder (at the expense of fuel economy of course). It allows for a higher performance engine, while maintaining the fuel economy that Toyota was after.
Re: (engineertwin2)
Posted: Mon Aug 11, 2008 5:30 am
by THE VIBERATOR
+1 to engineertwin2
Re: (engineertwin2)
Posted: Tue Aug 12, 2008 2:10 am
by Nelson
AHHHHhhh... I get it now. A second set of lobes, and more gas use...and more thrust.
Re: (Nelson)
Posted: Tue Aug 12, 2008 4:06 am
by 4X4CHICHI
I remember one time I didn't hit lift. No wait, 8 MONTHS, No lift...Wow.
Re: (northvibe)
Posted: Tue Aug 19, 2008 4:25 am
by ramenboy...
Quote, originally posted by northvibe »The 2zz loves to rev, it will not hurt it at all, in fact, I hear a kitten dies every time you dont hit lift hahahahahahahahahahahahawell said!
