rear molded mudflaps
Posted: Mon Apr 14, 2003 7:57 am
by zombie
anyone still have there instructions for installing rear mudflaps?i put them on and threw mine away ,then noticed they were not quite straight from the rear,i can't figure out what i did wrong.or if no one has them any idea where i might find them?thanks alot
Re: rear molded mudflaps (zombie)
Posted: Mon Apr 14, 2003 8:39 am
by ColonelPanic
quote: anyone still have there instructions for installing rear mudflaps?i put them on and threw mine away ,then noticed they were not quite straight from the rear,i can't figure out what i did wrong.or if no one has them any idea where i might find them?thanks alotI installed mine in late January (thankfully the parents have a heated garage) so anyway I'm not sure if the instructions are around any longer. It did take two attempts to get them on right for the rear, the fronts were a piece o' cake. IIRC, the instructions weren't all that great. Anyways, per the instructions... Jacked the rear up, one side at a time. Removed the tire, positioned the guard, and drilled the two holes through the cladding around the wheel well like the instructions said. IIRC, I don't remember seeing anything about removing a fastener from the bottom of the bumper. Dad was helping me with the project, he didn't notice it either. The fastener at the bottom was pushing the splash guards down a little, so they didn't line up right. Took the splash guards off, and removed the bottom fasteners from the bumper, (one one each side) drilled new holes in the cladding, and put the bolt/nut provided with the guards through the hole where the fastener went (sort of a pain to get that in.)The end result, check the pic attached. I took these yesterday when I was on my Vibe picture-takin' spree. Good luck, let me know if you need any more info!
Re: rear molded mudflaps (ColonelPanic)
Posted: Mon Apr 14, 2003 6:32 pm
by Stang2Vibe
That was the exact same thing that I had to do. It doesn't mention anything about taking out that body fastner undernieth. I followed the directions and had to drill a second set of holes on the one side. Good thing that the mudflaps covered up the holes. I saved my directions, too. I wanted to write to GM and tell them how badly the directions sucked for such a simple procedure. I'd love to "school" the genius engineer who wrote those lousy directions on how to write installation procedures for mudflaps.
Re: rear molded mudflaps (Stang2Vibe)
Posted: Mon Apr 14, 2003 11:29 pm
by ColonelPanic
Whew... Glad I wasn't alone. Whoever wrote those instructions.. LOL!
Posted: Tue Apr 15, 2003 4:55 am
by zombie
the directions were quite lousy,where did you put the washer?
Posted: Tue Apr 15, 2003 7:44 am
by ColonelPanic
The washer went on the bottom, between the head of the bolt and the mudflap.
Posted: Tue Apr 15, 2003 7:56 am
by pmh013
quote: I'd love to "school" the genius engineer who wrote those lousy directions on how to write installation procedures for mudflaps.At a company as big as GM, I doubt the engineers actually wrote the instructions (only small companies like the one I work for make us write instruction manuals!!). Probably, they were written overseas, and poorly translated.
Re: rear molded mudflaps (pmh013)
Posted: Tue Apr 15, 2003 10:15 am
by Stang2Vibe
I really don't think it could be a matter of translation, those directions were just flat out WRONG! They told you to use a size drill bit that you didn't need and the procedure was all backwards. If you work from the bottom up, everything is fine. If you follow the directions, it won't fit. A big DUH ! to whoever wrote those directions.I know that GM has its' own in-house people who write the owner's manuals. I met one of the guys who wrote the manual for the Fiero at the national Fiero show a few years ago. He was a GM employee. Some idiot with half a brain is out there writing directions for mudflap installation. They probably messed up a big project and got demoted to "mudflap installation direction writer". We got stuck with their poor handiwork that caused me to drill 2 unnecessary holes in my car.
Posted: Tue Apr 15, 2003 12:48 pm
by ColonelPanic
And to think, those who never follow directions would come out ahead in this case.
Posted: Tue Apr 15, 2003 4:40 pm
by Stang2Vibe
Unfortunately, this is sad, but true.
