New owner wants to program Auto lock door on 09
Posted: Tue Aug 05, 2008 7:43 am
by DAAKVIBE
Please anyone have the procedure how to do it ... tried the one for the older model 03-07 and it doesnt work ... please help me out...Ty
Re: New owner wants to program Auto lock door on 09 (DAAKVIBE)
Posted: Tue Aug 05, 2008 9:05 am
by KrazyB
I am not for sure about the 09's but you should be able to find it in your manual if not I can send you the one from my 05 manual.
Posted: Tue Aug 05, 2008 9:19 am
by Blueridge9
I hope someone can provide free instructions for an 09 but if not you might be able to get the instructions by purchasing an extra remote or maybe they'll sell you just the instructions (I never asked about that) athttp://www.carandtruckremotes.comI bought a new Matrix remote for my 04 Vibe there and it came with programming instructions that worked (on the third try).
Ok need help to program ... second try
Posted: Tue Aug 05, 2008 10:38 am
by DAAKVIBE
Ok let me explain in a more precise way ... my remotes work fine , the problem is i would like to have the doors getting locked as i drive out ,my Vibe is a stick shift and also as i turn the ignition off that the door would unlock, i have read the manual completly and nothing in there says anything about any procedure to change the settings...ty
Re: Ok need help to program ... second try (DAAKVIBE)
Posted: Tue Aug 05, 2008 10:42 am
by VforVIBE
I have a auto and it does it automatically, are you sure it doesn't lock and you just don't notice it?
Posted: Tue Aug 05, 2008 10:49 am
by DAAKVIBE
no im sure , ive had a saturn and another GM with manual transmision before and they both worked after i drove up to about 5mph ...
Posted: Tue Aug 05, 2008 10:57 am
In the 2009 "Get to Know your Vibe" thing (available in softcopy at http://forums.genvibe.com/zerothread?id=1010 ) on page 4 it talks about the auto door locks, but it says:Quote, originally posted by 09gtk »Automatic Transmission DoorLocking (if equipped)When shifting out of Park, this functionlocks all doors.Automatic Transmission DoorUnlocking (if equipped)When shifting to Park and turning thekey to ACC (Accessory) or Lock/Off,this function unlocks all doors.Seems that if they go to the trouble of saying automatic transmission in there, it likely doesn't apply to manual tranny models.
Re: (joatmon)
Posted: Tue Aug 05, 2008 11:10 am
by DAAKVIBE
I did call the dealer today and asked the man that answered me at the service dept and ive been told it was programable but cant find the info , i have an apointment thursday to have my rear windows Tinted with a dark shade so ill try to get the info on how to do it and will post then i hope... ty for the help you guys tried to do the best ... ty
Posted: Mon Sep 20, 2010 3:43 am
by 09Vibe
I'm guessing that since there was no repost on this topic it never got figured out ? I was reading on Toyota Nation and the Tundra Forums that Speed Sensor Auto Lock is a feature turned off on alot of Toyotas and the dealers have to turn them ON if the customer wants it via OBD II tools. So - I guess I will raise the question here again, has anyone with an 09 + Manual transmission, got it to work?
Re: (joatmon)
Posted: Mon Sep 20, 2010 4:34 am
by jake75
Quote, originally posted by joatmon »In the 2009 "Get to Know your Vibe" thing (available in softcopy at http://forums.genvibe.com/zerothread?id=1010 ) on page 4 it talks about the auto door locks, but it says:Seems that if they go to the trouble of saying automatic transmission in there, it likely doesn't apply to manual tranny models. So that would seem to say there is no way you can program it to NOT lock the door automatically.I like the feature on my T&C better - only locks when you get to a certain speed. On the Vibe, I get in, back it out of the garage and it is already locked and my better half gets irritated that she can't open the door. I then fumble around to find the door unlock button.
Posted: Mon Sep 20, 2010 12:21 pm
by 09vGT
I thought I've read on here somewhere that you can have them programmed to lock and unlock at different times.. I may be wrong though.. I just wish mine would unlock when putting the car in PARK instead of turning it off..
Posted: Tue Sep 21, 2010 12:44 am
by 09Vibe
I'd assume if the Matrix electronics lock the doors via a signal from the speed sensors it does not matter if the vehicle is auto or manual. On auto you can select the option of locking by shift out of P or not. So on the manual - it should lock at the same time the vehicle speed sensors show movement (similar to the warning beep relay if you don't have your belt on, they get the signal from the speed sensors) But - somone with a GM OBD tool would have to look at the modules and confirm... I dunno if I want to pay for them to search this feature out. I know that you can program the unlock relay on the manual when you turn the key to off (pressing down 6 times on the door lock button with the key on, then pressing unlock once)... but it does not work in reverse (locking when the vehicle gets started)
Posted: Sat Oct 30, 2010 8:43 am
by frankiemenz
I have/own a GM TECH2, I have set and changed the remote functions in my Vibe, such as dome light delay, lock and unlock functions and the auto-lock functions if the door is not opened after unlock is pushed. I can help out memebers in the Rochester, NY area if you would like. I think the dealer will do it for free for the 3/36000 warranty, there may be a charge thereafter.PM me for help----Frank
