Brass shifter bushings, do they work?
Posted: Tue Aug 05, 2008 1:42 am
by KNINE
I saw these brass shfter bushings on ebay. Does anybody know if they eliminate that plastic feeling from the 5-speed shifter? I did a search on shifter bushings and didn't find anything.
http://cgi.ebay.com/ebaymotors...ZWDVW
Re: Brass shifter bushings, do they work? (K-NINE)
Posted: Tue Aug 05, 2008 6:17 am
by Raven
They're excellent. One of the best mods I've done. gives a much more precise feeling in the shifter.
Posted: Tue Aug 05, 2008 9:58 pm
by Herb
It definately helps. As for the plastic feel, that might be because the shifter really IS made of plastic.
Posted: Mon Aug 11, 2008 6:38 am
by DarkSpork
If anybody decides to go forth with this modification, could you take pictures? I hate the feeling of the shifter in vibe, sloppiest feeling shifter of any car I have driven.
Re: Brass shifter bushings, do they work? (DarkSpork)
Posted: Mon Aug 11, 2008 7:48 am
by KNINE
I just ordered a set today. I'll let you know.
Posted: Mon Aug 11, 2008 9:13 am
by SeattleJeremy
Looks like I'm a little late to this thread, but yes, they are worth every penny. Much easier to shift, more direct, not mushie.
Posted: Mon Aug 11, 2008 9:27 am
by northvibe
yeah i have them for my ms3, they help with the "slop"
Posted: Mon Aug 11, 2008 2:24 pm
by DarkSpork
Quote, originally posted by K-NINE »I just ordered a set today. I'll let you know.Thanks. This is one of the few upcoming purchases for the car I'm looking forward to.
Posted: Tue Aug 12, 2008 12:52 am
by northvibe
I just reinstalled my shifter bushings into my car (they were like that aircraft aluminum). WOW i forgot how much they helped. So stock has those rubber bushings in, so the feel is a soft shift, smooth etc. but since its rubber and can move its "sloppy" but easy going. After the bushings were in, its a tight, straight shift feel. Like mechanical. Were you go to shift and thats what your doing, not soft, not smooth but right to the point. Feels good.
Posted: Thu Sep 25, 2008 8:45 am
by bodhi_tree777
Hey, K-9, did you ever install these? Just got mine in the mail, was wondering how easy or hard the install was? I've read up a bunch on them and I've seen photos of them installed, but no step by step instructions were included. Also, I've read that I should clean and lube the linkages down there, what would you use to clean them?
Re: Brass shifter bushings, do they work? (bodhi_tree777)
Posted: Thu Sep 25, 2008 10:12 am
by DarkSpork
Quote, originally posted by bodhi_tree777 »Hey, K-9, did you ever install these? Just got mine in the mail, was wondering how easy or hard the install was? I've read up a bunch on them and I've seen photos of them installed, but no step by step instructions were included. Also, I've read that I should clean and lube the linkages down there, what would you use to clean them? Hey, would you mind taking pictures of the install for me ?
Posted: Thu Sep 25, 2008 10:17 am
by bodhi_tree777
Quote, originally posted by DarkSpork »Hey, would you mind taking pictures of the install for me ?sure, if I can do it correctly . They may only be good for a laugh, as I've never attempted anything like this before. Seems easy enough though.
Posted: Thu Sep 25, 2008 10:24 am
by DarkSpork
Thanks. I've been meaning to do this mode but I don't know how to find the bushing on the linkage.
Posted: Thu Sep 25, 2008 10:28 am
by bodhi_tree777
they're pretty easy to find, actually. Pop your hood and look down past the cruise control, near the airbox. To make it easier, have someone shift through the gears while you're looking. They are the moving parts at the end of the accordian-looking arms. If you can get your car up on jacks or ramps you can see them easily.
Posted: Thu Sep 25, 2008 10:33 am
by DarkSpork
Thanks. I'd still greatly appreciate it if you can take pictures for me though .
Posted: Mon Sep 29, 2008 12:07 am
by bodhi_tree777
okay, I'm going to try and get these installed this week. Questions, though.. I've read that the SpeedSource bushings are labeled upper and lower, and are slightly different in size. Mine (which I assume aren't from SpeedSource, i purchased them from a genvibe member here) are exactly the same size. Should I be worried?Also, there's been some debate about whether to use the stock pins that come with the vibe or use the ones that come with the brass bushings. Mine didn't come with any, so I'm going with stock I suppose. Should I be worried about that either?
Posted: Mon Sep 29, 2008 12:50 am
by KNINE
I bought a set of Summit bushings from ebay about a month ago, but I've been too busy to put them in. I can't remember if mine came with pins. I'll have to look when I get home. So I guess I was a big help, wasn't I?
Posted: Mon Sep 29, 2008 7:17 am
by KNINE
I just looked at my Summit bushings and no pins are included, so I assume that we reuse the stock pins.
Posted: Mon Sep 29, 2008 9:54 am
by bodhi_tree777
Quote, originally posted by K-NINE »I just looked at my Summit bushings and no pins are included, so I assume that we reuse the stock pins. are yours both the same size?
Posted: Mon Sep 29, 2008 11:30 pm
by KNINE
I'll take a look when I get home from work.
Posted: Tue Sep 30, 2008 6:54 am
by KNINE
Both of mine are the same size.
Posted: Wed Oct 01, 2008 6:27 am
by bodhi_tree777
I meant to get to this today, my last day off this week. Instead, I bit the bullet and bought new tires instead. Goodyear Assurance TripleTreads, the difference is like night and day. Then again, my Yokohamas were like slicks at this point .Bushings go in next week, I hope. Any tips up til then are much appreciated
Posted: Wed Oct 01, 2008 11:21 pm
by bonzo4ever
Highly recommended. I got mine for about 23 bucks with shipping. Felt like a whole new shifter when I got done, without spending the $300+ on a short shifter (although that would be nice).
Posted: Thu Oct 02, 2008 12:32 am
by Herb
Quote, originally posted by bodhi_tree777 »Bushings go in next week, I hope. Any tips up til then are much appreciated It's alot easier than you might think. The only thing I would suggest is not to install them when parked on grass, in case you drop the pin. In my case TWM provided pins so when I lost one in the grass I ended up using one of the stock pins.I tried taking a photo of where it's at, but it doesn't show well now. I should have done it when I was installing it.
Re: Brass shifter bushings, do they work? (Herb)
Posted: Fri Oct 03, 2008 2:13 pm
by DarkSpork
Quote, originally posted by Herb »It's alot easier than you might think. The only thing I would suggest is not to install them when parked on grass, in case you drop the pin. In my case TWM provided pins so when I lost one in the grass I ended up using one of the stock pins.I tried taking a photo of where it's at, but it doesn't show well now. I should have done it when I was installing it.Well if you still have the picture it may help me. I guess what I need to do is get it on the lift and have one of my friends fool with the shifter so I can see the linkage moving and from there I should be able to figure out where the bushings are. Thanks.
Posted: Sat Oct 04, 2008 1:01 am
by Herb
I didn't need a lift. It can be installed from above and I found it would be easier. This shot is to give you a point of reference, and so I can show off my engine bay...
Posted: Sat Oct 04, 2008 1:17 am
by Herb
Here's a close up with the bushings circled
Posted: Sat Oct 04, 2008 1:50 am
by bodhi_tree777
awesome, thanks (and nice bay, btw). Did you have to remove anything to get down there, or did your intake give you enough room? I have a stock airbox so I think I'll have to unbolt and move my cruise control to access these (or get it up on a lift somewhere).
Posted: Sat Oct 04, 2008 2:08 am
by Herb
Quote, originally posted by bodhi_tree777 »awesome, thanks (and nice bay, btw). Did you have to remove anything to get down there, or did your intake give you enough room? I have a stock airbox so I think I'll have to unbolt and move my cruise control to access these (or get it up on a lift somewhere). I didn't have to remove anything, but then I already had the CAI installed by that time. I believe you would have to remove the airbox to get access. I don't recall having to remove the cruise control. All you need for tools would be a needle nose pliers to remove the retaining pins
Posted: Sat Oct 04, 2008 2:20 am
by bodhi_tree777
thanks Herb. Last question, were your 2 bushings the same size, or slightly different?
Posted: Sat Oct 04, 2008 2:35 am
by Herb
Quote, originally posted by bodhi_tree777 »thanks Herb. Last question, were your 2 bushings the same size, or slightly different?To be honest, I don't remember any mention of differing sizes. I just looked at the stock bushings and they seem to be the same.
Posted: Sat Oct 04, 2008 2:48 pm
by DarkSpork
Quote, originally posted by Herb »I didn't have to remove anything, but then I already had the CAI installed by that time. I believe you would have to remove the airbox to get access. I don't recall having to remove the cruise control. All you need for tools would be a needle nose pliers to remove the retaining pinsThanks Herb, I think I'm going to order some, it looks pretty easy. And if it makes my shifter feel less cheap and sloppy I will be quite happy. Nice looking engine bay by the way.
Posted: Sat Oct 04, 2008 3:02 pm
by Herb
Quote, originally posted by DarkSpork »Thanks Herb, I think I'm going to order some, it looks pretty easy. And if it makes my shifter feel less cheap and sloppy I will be quite happy. Nice looking engine bay by the way.It's probably one of the easiest mods to do. I got the ones from TWM when I ordered my short shifter. I installed both at the same time so I can't tell what difference each individual mod had. Guess I should have done them in stages. In anycase the TWM set came with instructions and photos, although it was for a Celica.Let us know what you think of the improvement overall.Thanks for the compliments. I need to take more time to detail the engine bay though.Oh and here's a shot of the short shifter I installed as well
Posted: Sun Oct 12, 2008 1:04 pm
by DarkSpork
Got them in the mail today, hopefully weather will permit me to install them tomorrow (its supposed to snow again).
Posted: Tue Oct 14, 2008 4:15 am
by DarkSpork
Changed the bushings today. It was pretty straight forward, the hardest part was getting the old ones off. The vertical one was the most difficult and the horizontal one had rubber pieces fall off as I pulled the arm off the pin. I didn't have to remove anything, and it took about 20 minutes. Shifting feels more precise, there is less play in the shifter and it seems to go into gear easier, only gear that isn't easy is downshifting into 2nd (but it is much improved from before). This was worth the $28. Thanks Herb for the pictures, it helped me figure out exactly where to look.I attached a picture of the old bushings. Didn't bother to take pictures of the install because there was too much in the way to get a decent picture.
Posted: Tue Oct 14, 2008 7:17 am
by Herb
Quote, originally posted by DarkSpork »Changed the bushings today. It was pretty straight forward, the hardest part was getting the old ones off. The vertical one was the most difficult and the horizontal one had rubber pieces fall off as I pulled the arm off the pin. I didn't have to remove anything, and it took about 20 minutes. Shifting feels more precise, there is less play in the shifter and it seems to go into gear easier, only gear that isn't easy is downshifting into 2nd (but it is much improved from before). This was worth the $28. Thanks Herb for the pictures, it helped me figure out exactly where to look.Glad I was able to help. I don' t think I had any problems removing mine, but that's the reason they include some sand paper to help clean out the area in case the rubber bushings fell apart.
Posted: Tue Oct 14, 2008 9:23 am
by DarkSpork
Your pictures helped a lot. It seemed that there was nothing I could remove that would really make it any easier.
Posted: Tue Oct 14, 2008 9:55 am
by Herb
Quote, originally posted by DarkSpork »Didn't bother to take pictures of the install because there was too much in the way to get a decent picture.That was the same reason I didn't photograph the installation too. And the instructions I got with my bushings were reasonable.
Posted: Tue Oct 14, 2008 10:48 am
by harryyiii
see attached installation manual
Attached files celica_matrix_tc_corolla_cable_bushings.pdf (728.1 KB)
Re: Brass shifter bushings, do they work? (harryyiii)
Posted: Tue Oct 14, 2008 10:58 am
by Herb
Quote, originally posted by harryyiii »see attached installation manualThese were the instructions that came with my set, though printed in B&W. Funny thing was that I tried to find this on the TWM website but was unable to locate it.Thanks for posting it.
