Cost to GM to replace window bolts
Posted: Thu Jul 31, 2008 2:55 am
by jake75
I briefly saw the dealer copy of the work order. The labor listed was $78 and the bolt a few bucks.I had a LOF done at the same time - was in and out in under an hour.Wonder if the company that supplied the defective bolts has to cover that.
Posted: Thu Jul 31, 2008 3:03 am
by engineertwin2
Likely, the "defective bolts" were really defective engineering for the secure point/technique. To my knowledge, the bolts were backing out, not simply shearing under the stress. Given that they were backing out, it is likely that the engineer simply was not conservative enough in his vibration assumptions through the window channel. It could have also been something like a last minute savings cut (either new supplier or slimmer material, etc) could have impacted the NVH properties without a proper analysis.Translation: This stuff happens. Since it isn't a specific material defect, I'm taking my money to Vegas and placing it all on GM is covering the cost.
Re: (engineertwin2)
Posted: Thu Jul 31, 2008 5:17 am
by jake75
Aside from who pays - I thought the $78 labor was quite generous for a job that obviously took less than 1 hour.
Posted: Thu Jul 31, 2008 5:25 am
$78 an hour doesn't seem unreasonable considering all the overhead costs for a dealer service center.what is an LOF?
Re: (joatmon)
Posted: Mon Aug 04, 2008 8:44 pm
by ou.grizzly
Quote, originally posted by joatmon »what is an LOF?Lube, Oil, and Filter?$78 dollars seems to be the going rate now for "per hour" labour at any dealership.Question is did it actually take the mechanic one full hour or less. Not sure what the entire process does entail, but the inside door panel may needed to be removed.
Posted: Mon Aug 04, 2008 10:17 pm
by northvibe
they usually bill by average "how long this job should take" even if it took 20 min they still get paid 1 hour to the shop.speaking of which my sister just had this done to my old vibe, i guess the window start to make loud noises after i sold it
Re: (ou.grizzly)
Posted: Tue Aug 05, 2008 2:23 am
by Blueridge9
Quote, originally posted by ou.grizzly »$78 dollars seems to be the going rate now for "per hour" labour at any dealership.How much does the mechanic in the dealership get paid an hour?
