Need Help :(
Posted: Mon Jul 21, 2008 12:52 am
by mozafari
basics:2005 pontiac vibeabout 70k milesautomaticproblem:every so often, the gas pedal will give up while i'm driving. the engine will still run and everything like normal, except when i press on the gas, nothing happens. no rev'ing, no acceleration, nothing. i have to turn the car off and turn it back on for it to work.pleeeease help. tell me what's wrong. thanks
Re: Need Help :( (mozafari)
Posted: Mon Jul 21, 2008 2:41 am
by CountryVibe
Have to tried to reset the ECU?the throttle body on the 05 are electric and could not be sending the right signals , also might want to check the wires to see if any are loose,It that does not fix the problem the throttle body control module might be going bad.
Posted: Mon Jul 21, 2008 2:31 pm
by coldmm803
welcome to the board.i'm not sure what the solution could be but i'll add to Country Vibe's post. to reset the ECU just unplug the battery for 15-20 minutes
