My Sub setup.
Posted: Sat Jul 12, 2008 5:21 am
by Kevzaz
Recently, I got my new bass system in.It is One 12" RE SXand a 2000Watt Fusion AmpHits REALLY REALLY hard. And It sounds awesome.
Posted: Sat Jul 12, 2008 10:51 pm
by Sublimewind
VERY cool man..... What made you decide to go with RE..?? It's kind of an obscure company and "most" don't even know about them... They usually start with the big 10 companies... What are you going to use to keep it from sliding around?I can't comment much on the fusion amp, don't know much about them... I see a lot of eye flash gimmicky things happening with it though... Doesn't matter if it sounds good right...!!! Good show mang...
Posted: Sun Jul 13, 2008 2:40 am
by Kevzaz
I decided to go with R.E. because I heard they were a great company that you cannot really go wrong with. The sub hits hard and sounds great, which is good cause I listen to all types of music. I didn't have to do much to keep it from sliding around since it is already very heavy, so I just got 3 pieces of Velcro and sha-zam. =p
Re: (Kevzaz)
Posted: Sun Jul 13, 2008 10:55 pm
by Sublimewind
Quote, originally posted by Kevzaz »I decided to go with R.E. because I heard they were a great company that you cannot really go wrong with. The sub hits hard and sounds great, which is good cause I listen to all types of music. I didn't have to do much to keep it from sliding around since it is already very heavy, so I just got 3 pieces of Velcro and sha-zam. =pYou might consider something a bit more "sub-stantial" than velcro, if you were to get into a accident(and hoping you don't) you could end up with RE stamped in the back of your noggin... lol.. I bet you could get some L brackets, screw them into the box and then use the BASE of the hatch hold downs and run a bolt though them, to hold it down AND not put any holes in the cover... Something to consider..
Posted: Mon Jul 14, 2008 12:15 am
by Kevzaz
Wait, how could I do it without having to drill holes in the hatch?
Re: (Kevzaz)
Posted: Mon Jul 14, 2008 10:55 pm
by Sublimewind
Quote, originally posted by Kevzaz »Wait, how could I do it without having to drill holes in the hatch?The floor has them rails for the tie-downs, if all lined up right(or if you drilled them to line up right), you could bolt the L-brackets into the BASEs of the tie down brackets, which I think are just special T-nuts that slide into the tracks.. All you would have to have, would be bolts that are both the right thread and the right length to bolt into the the tie-downs..
Re: (Sublimewind)
Posted: Mon Sep 15, 2008 6:46 am
by statman
Is the cargo area still useable at all? I dont own a Vibe so im not sure how it works, does the whole floor lift up as once piece to show the area with the nets, or does it come up in sections? If its in sections then Id assume half of this area is still functional, otherwise if it comes up as one piece then its not?
Posted: Mon Sep 15, 2008 11:58 pm
by Sublimewind
The floor is in one section, and the box shown above can easily come out, if needed to get under it.. There aren't a lot of options for the vibe.. having something removable is the best on i've come up with, as you get your cake and eat it to... Some have spare tire well enclosures, which are nice, but labor and money intensive... Other have side panel enclosures, same thing... It's all up to how far you want to take it..
Posted: Tue Sep 16, 2008 4:35 am
by wyatt89
EXCELLENT choice on the RE, that thing will serve you for a long time, those are built really well. How big is that box?
Posted: Sun Sep 28, 2008 2:36 am
by Kevzaz
Sorry, I forgot I even made this thread... lol. I can still access the area below the box. The box is 1.5 cubic feet. Not too sure on the dimensions. The only problem is that the sub is rattling, I have no idea what its from. I heard it could be anything from the box itself rattling, to tinsel slapping, or even a syder broke on the sub. haha
