Hub Cap Lug Nut Question
Posted: Thu Jul 10, 2008 9:02 am
by mikey00
I noticed that when I tighten the plastic lug nuts that keep the hub cap on, they reach a certain point then release. Almost as if they were stripped. Nothing looks like it is stripped. I am wondering if they are designed to work that way so you can't over tighen them or if I have a real problem most likely caused by the impact wrench happy animals at the tire shop. Anyone else notice this?
Re: Hub Cap Lug Nut Question (mikey00)
Posted: Thu Jul 10, 2008 9:20 am
by Raven
Yes, that's the way they're made. I use my steelies with hubcaps in the winter. What I do is tighten them until they release and then snug them to just before the release point. I find you get fewer rattles that way.
Posted: Fri Jul 11, 2008 1:26 am
by altimar
I think they were made to be only hand-tightened. I never even tried using a wrench on them. Yours may be stripped, but they'll probably be fine unless you like hitting potholes at insane speeds.
Posted: Fri Jul 11, 2008 1:38 am
by northvibe
yup sounds like if you over tighten them they get pushed back out a turn (thread). Do what raven does or until they are tight (right before "release".)
Posted: Fri Jul 11, 2008 2:47 am
I do that all the time.Quote, originally posted by Raven »Yes, that's the way they're made. I use my steelies with hubcaps in the winter. What I do is tighten them until they release and then snug them to just before the release point. I find you get fewer rattles that way.I agree (except I'm year round on steelies&covers)
Posted: Fri Jul 11, 2008 8:52 pm
by mikey00
Thanks guys. It's good to know that nothing is stripped on mine and it is working as designed. Actually, I guess it's a good idea. It keeps some tire guy with an impact wrench from stripping out your plastic lug nut.
