Getting water inside car in a very weird place
Posted: Fri Jun 27, 2008 1:05 pm
by Burns1210
After a good rain or car wash, I've been noticing a drop or two of water on the plastic trim above the small side window in the cargo area. The water is not on the window, but on the plastic above the window and below the headliner. Where on earth could that be coming from?
Re: Getting water inside car in a very weird place (Burns1210)
Posted: Fri Jun 27, 2008 3:28 pm
by kostby
Do you have a sunroof? If yes, then in Generation I Vibes (2003-2008) there is a blue drain hose from the passenger side of the sunroof cavity that runs down the pillar in front of the small rear window. I'd guess that either it's plugged or perhaps cracked.Here's a link to a thread with photos I posted in a discussion about it in 2006 --> http://forums.genvibe.com/zerothread?id=25645If no sunroof, I'm stumped.
Posted: Fri Jun 27, 2008 3:35 pm
by Burns1210
Nope. No sunroof.
Re: (Burns1210)
Posted: Fri Jun 27, 2008 7:37 pm
by Raven
Perhaps it's getting in around the base of the antenna and trickling over to the side.
Posted: Fri Jun 27, 2008 8:31 pm
by WaveAction
but why would it just be on the one side and not the other? unless its getting on both sides..then that might be a possibility..another thing is maybe the roof rack?? where the screws go into the actual roof perhaps?
Re: (WaveAction)
Posted: Fri Jun 27, 2008 9:13 pm
by Burns1210
Quote, originally posted by WaveAction »but why would it just be on the one side and not the other? unless its getting on both sides..then that might be a possibility..another thing is maybe the roof rack?? where the screws go into the actual roof perhaps?I was going to mention that the drops of water do appear straight below the rear roof rack mount. I wasn't sure how the rails are attached to the roof, whether there are bolts through the skin of the roof or it is just attached to the top somehow.I'll have to get inside the car and have someone run a hose and try to see at least what direction the water is coming from.
Posted: Fri Jun 27, 2008 10:54 pm
If it were me, I'd take off that trim panel to see behind it when you have someone hose the car. It could be the seal around the top of that fixed glassYou should also check the floor pan at the spare tire to see if any water has collected, I don't know if there is a drain or weep hole down there
Posted: Sat Jun 28, 2008 3:15 am
by Herb
Perhaps dropping the headliner will help you diagnose the problemHere's a link to the thread on how to do it:http://forums.genvibe.com/zerothread?id=4600
Re: Getting water inside car in a very weird place (Herb)
Posted: Sun Jun 29, 2008 11:23 am
by Burns1210
The car is still under warranty, I'll be taking it in. I just don't like taking a car in blindly, not knowing exactly what the problem is...even though the work is free. I have a feeling it has something to do with the roof rack, and I can only imagine what it looks like behind the panels back there.
