				What is this part?
				Posted: Thu Jun 26, 2008 9:19 pm
				by Bri in Mtl
				New member and 1st post.Bought a used 2005 w/only 35,000K and found this piece of plastic in the glove box.Anyone know where it goes and what it's for?Thanks in advance.
				Posted: Thu Jun 26, 2008 9:23 pm
				by bull77
				I think I've seen that piece before --- check the seatbelt buckle by the floor, I think its the cover..
				Posted: Thu Jun 26, 2008 10:06 pm
				by Bri in Mtl
				Doesn't appear to be it.
				Re:  (bull77)
				Posted: Thu Jun 26, 2008 10:53 pm
				by BlueCrush
				Quote, originally posted by bull77 »I think I've seen that piece before --- check the seatbelt buckle by the floor, I think its the cover..Close! It goes on the REAR of the front seat rail next to the floor. Check those and you'll see where and how it goes on. It was probably kicked off by a rear passenger at some point when it was owned by the previous owner. It was probably in the glove box because it is a pain in the a$$ to get back on. Good Luck!
				Posted: Thu Jun 26, 2008 11:21 pm
				by lovemyraffe
				Quote, originally posted by BlueCrush »Close! It goes on the REAR of the front seat rail next to the floor. Check those and you'll see where and how it goes on. It was probably kicked off by a rear passenger at some point when it was owned by the previous owner. It was probably in the glove box because it is a pain in the a$$ to get back on. Good Luck!I was going to say the same thing.
				Posted: Fri Jun 27, 2008 12:53 am
				by Bri in Mtl
				AHA!!  That's it!Thanks a bunch!
				Posted: Fri Jun 27, 2008 2:36 am
				by AKLGT
				yep, rear seat belt bolt cover.
				Posted: Fri Jun 27, 2008 4:28 am
				by zionzr2
				+1 to the othersI guess I'm a bit late to the party!
				Re:  (zionzr2)
				Posted: Fri Jun 27, 2008 6:08 am
				by BlueCrush
				Quote, originally posted by zionzr2 »+1 to the othersI guess I'm a bit late to the party!You need to be a little quicker on the draw...Wild Bill!
				Posted: Fri Jun 27, 2008 6:42 am
				by ColonelPanic
				I swear mine would fall off if I looked at the seat track, those stupid things!   And I could never get them back on right.
