Monotone paint poll
Posted: Wed Apr 09, 2003 11:21 pm
by NovaResource
In response to this post: http://forums.genvibe.com/zerothread?id=3554Did your monotone Vibe come with a protective sheet of polyurethane on the lower cladding?
Re: Monotone paint poll (NovaResource)
Posted: Wed Apr 09, 2003 11:29 pm
by NSimkins
I'm not exactly sure if this is the same thing, but I have a small (6"x4" approx.) piece of clear plastic on the lower monotone cladding in front of the rear wheel wells.One side is clear, but the other looks a little yellowed-out. Over the winter, it does not look like that area took any bad beating considering I did drive in the slag and salt they dump around this area.I'll try to snap a pic when I get home, unless someone else beats me to it.Honestly, I never checked another monotone Vibe (or two-tone for that matter) to see if they also had the same plastic film.
Re: Monotone paint poll (Salsa!)
Posted: Wed Apr 09, 2003 11:41 pm
by Triton
Nick, you do have it on there. I have it as well. My dealer said it will help protect it for a while. If it starts bubbling or peeling, it can be removed.
Posted: Thu Apr 10, 2003 12:30 am
by NSimkins
quote:That's what happens often with these things, they get yellow after being exposed to sun and different weather conditionsThat's what I assume as well. I put some cleaner wax on the "yellowed" side and it did improve somewhat. There is a TSB out there about replacing the body moldings due to road debris.quote:Wheel House Opening Molding Discolored (Replace Molding) #02-08-111-005 - (09/10/2002)Wheel House Opening Molding Discolored (Replace Molding)2003 Pontiac VibeConditionSome customers may comment that the rear wheel house opening molding or the rear door lower molding is discolored.CauseRoad debris contacting the molding may discolor the moldings.CorrectionReplace the moldings and clips.By this description, this does sound like the portion I was referring to.
Re: Monotone paint poll (NSimkins)
Posted: Thu Apr 10, 2003 1:03 am
by NovaResource
I stand corrected. It appears that Pontiac actually did do this. I guess it was to protect the paint and not the cladding since unpainted cladding doesn't have this.For those who want to add it to their 2-tone cladding or replace the factory decal, go here:http://www.griotsgarage.com/search.jsp? ... search.y=9
Posted: Thu Apr 10, 2003 10:55 pm
by Yoda
I thought it was a paint defect when I first saw the piece in front of the right rear wheel opening (at delivery). Then I noticed that it was ll over the lower cladding. Mine's black, so no signs of yellowing. I will have to be careful not to leave any wax on the edge when I was it this spring...
Re: Monotone paint poll (Yoda)
Posted: Sun Apr 13, 2003 3:26 pm
by Kissfan79
Forgive me for being a dumb (removed).....what exactly is this coating or tape on the cladding of the monotone paint? Does anyone have a picture of what they are talking about?Thanks, Jim
Re: Monotone paint poll (Kissfan79)
Posted: Sun Apr 13, 2003 3:56 pm
by meathead333
id like to see one too, i am a dumb (removed) also
Posted: Sun Apr 13, 2003 7:55 pm
by NSimkins
quote:Does anyone have a picture of what they are talking about?I posted a pic in the thread "Sand blasting effect on cladding..". Here is the direct link:http://forums.genvibe.com/zerothread?id ... 6683#36683
Posted: Mon Apr 14, 2003 1:04 am
by Kissfan79
I do indeed have this coating on my Vibe. It does not, however, look clear. I looks as though it is the ssame color as my paint (Abyss). Can you just peel this stuff off if you want to?Jim
