New Deck
Posted: Wed Jun 25, 2008 6:58 am
by WaveAction
well i purchased a new deck for the vibe, havent installed it yet, but will shortly! very excited and love it so far(looks wise) i picked up the Alpine CDA-9886, got it from a friend.
Re: New Deck (WaveAction)
Posted: Wed Jun 25, 2008 10:37 am
by kunkstyle
That's a nice packing job there...Looks sharp - good luck on the install!
Posted: Wed Jun 25, 2008 11:38 am
by waveresponder
nice! cant wait to see pics of it installed!
Posted: Thu Jun 26, 2008 6:07 am
by Sublimewind
That is a GREAT deck... good job mang... !!!
Posted: Fri Jun 27, 2008 7:06 am
by WaveAction
thanks, just gotta do the wiring still and plop it all in..i'd like to solder it and use the heatshrinks to make it nice and clean...so just matching up the wires now and gotta find/buy a soldering kit, not expensive and its handy if i need it later on
Posted: Sun Jun 29, 2008 8:22 am
by WaveAction
well im done the soldering part of the harnesses...now it's just a matter of taking out the stock deck and slapping in the new one..will have pics up tomorrow after work! heres a few pics of the harnesses, cut the Alpine one down quite abit, then did the barrel knot as sublime posted in his "how-to" then used heatshrink tubes to cover them up..theirs a few i forgot to put the tubes on first then solder, thats why theirs about 4 or 5 that has tape on them insteadstock harness(bottom) and the alpine harness on the topmy "barrel knot"harness all completei had 4 left over wires 3 from the alpine harness and 1 from the stock one so i used a heatshrink tube and folded the end of it in to make a noose type thingand heres a couple of of the connections after soldered and heatshrunk
Re: (WaveAction)
Posted: Sun Jun 29, 2008 9:33 am
by keithvibe
whats with the photos of wires... wheres the photos of the install?
Posted: Sun Jun 29, 2008 9:52 am
by WaveAction
you obviously didnt read the first sentence of the post i said im installing it tomorrow..
Re: (WaveAction)
Posted: Sun Jun 29, 2008 10:03 am
by kunkstyle
What's the hold up? The wiring is what takes the longest.
Re: (WaveAction)
Posted: Sun Jun 29, 2008 10:20 am
by keithvibe
I did buddy.. just buggin ya and by the way put some dame shoes on
Posted: Sun Jun 29, 2008 10:50 am
by WaveAction
lol and get my white carpet dirty? i think not! and ya the wiring took me about an hour..but had other things to do so didnt get to the installing..thats why it's tomorrow
Re: (WaveAction)
Posted: Sun Jun 29, 2008 11:26 am
by Burns1210
Instead of connecting the wires like that before soldering, I've found it easier hooking the exposed wire together like two candy canes, then soldering.
Posted: Sun Jun 29, 2008 11:30 am
by WaveAction
i found it easier like this so i can get the heatshrink tubes over top of them..i only had the 1/8th diameter tubes but it worked good, doesnt really matter how you do it
Posted: Mon Jun 30, 2008 1:25 am
by Sublimewind
EXCELLENT work man.... !!! Those knots look MUCH better than the ones I posed... Maybe I could borrow that one pic for my install tutorial?? It would definitly represent what I was trying to show MUCH better...Now, for the install pics..
Re: (Burns1210)
Posted: Mon Jun 30, 2008 1:27 am
by Sublimewind
Quote, originally posted by Burns1210 »Instead of connecting the wires like that before soldering, I've found it easier hooking the exposed wire together like two candy canes, then soldering.That technique "works" but doesn't lay as flat as a barrel knot, it also has a possibility of stressing the solder to the point of failure(less surface area conected by solder), more so than the barrel knot but that is somewhat far fetched.
Re: (Sublimewind)
Posted: Mon Jun 30, 2008 6:37 am
by WaveAction
Quote, originally posted by Sublimewind »EXCELLENT work man.... !!! Now, for the install pics.. so far i love the deck, i gotta play around with it abit and see what i can and cant do..and of course i forgot my cable for the ipod so i may have to take the deck out again just to plug it in..unless i can find away to get my hand up behind or even through the glove compartment to get to the loose wire
Re: (WaveAction)
Posted: Mon Jun 30, 2008 7:01 am
by kunkstyle
Quote, originally posted by WaveAction »and of course i forgot my cable for the ipod so i may have to take the deck out again just to plug it in..unless i can find away to get my hand up behind or even through the glove compartment to get to the loose wireGood luck with that. I had to fish mine in from the top down.Looks sharp in the Vibe. I hope you at least had some socks on when you went out to the car...
Posted: Mon Jun 30, 2008 7:20 am
by keithvibe
looks good buddy
Posted: Mon Jun 30, 2008 10:14 am
by WaveAction
lol i was at work..so yes i had socks on..the other pic without socks was in my room smartass
Re: (WaveAction)
Posted: Mon Jun 30, 2008 10:17 am
by kevera
You must be new,taking all these pics and none with the radio on.
Posted: Mon Jun 30, 2008 10:28 am
by WaveAction
i am new i will get a pic of it on..and another at night
Re: (WaveAction)
Posted: Mon Jun 30, 2008 10:35 am
by kevera
Quote, originally posted by WaveAction »i am new Ahahaha,cool deal.
Re: (WaveAction)
Posted: Thu Jul 03, 2008 1:08 pm
by TinleyJake
I have the same radio and install kit. It's like you took a picture of my dash. Best receiver I have ever had and I've gone through 6 different ones in the last two years. Unfortunetly, even though I've only had this unit for 3 months, I'm replacing it next week with the 9887 model with the built in crossovers in order to run my speakers active.The Ipod controls with the dedicated cable are the best I've used. I installed the cable in the opening below the radio so I had easy access to remove the Ipod.Are you planning to use the USB?
Posted: Sat Jul 05, 2008 11:57 am
by WaveAction
probably not gonna use the USB...i have my ipod hooked up to it..i have it running underneath the shifter along the center console..and ya..havent really done much other then that..but so far i love this receiver aswell..couldnt be happier..just 1 little thing annoys me...is when i first put the faceplate on..sometimes it takes a few tries to get it on properly
Re: (TinleyJake)
Posted: Sun Jul 06, 2008 11:26 pm
by Sublimewind
Quote, originally posted by TinleyJake »I have the same radio and install kit. It's like you took a picture of my dash. Best receiver I have ever had and I've gone through 6 different ones in the last two years. Unfortunetly, even though I've only had this unit for 3 months, I'm replacing it next week with the 9887 model with the built in crossovers in order to run my speakers active.The Ipod controls with the dedicated cable are the best I've used. I installed the cable in the opening below the radio so I had easy access to remove the Ipod.Are you planning to use the USB?I want to hear more about your active set-up... As you are new, I don't know you yet(welcome BTW), and I would like to make sure you are getting into "active" correctly... I'll be running active through an Alpine h701 processor with the c701 cotroller, no HU, just a modded xBox running optical into the 701...!!! woot woot.... lol...
Posted: Mon Jul 07, 2008 5:13 am
by Celtic_Curse
Great choice in Decks. I'm a big Alpine fan. great job on the install.
Posted: Mon Jul 07, 2008 10:40 am
by WaveAction
thanks man..i really like the alpines too..it was either that or a pioneer..but liked the features and the price i got for the alpine so i picked it up..love it so far..i usually have it at 7..and it's loud lol..so im sure to blow my stock speakers soon
