De-Badge
Posted: Tue Apr 08, 2003 7:47 am
by 30yr_old_fogey
How do you remove the Nameplates? Heat gun?Thanks,Bryan
Re: De-Badge (30yr_old_fogey)
Posted: Tue Apr 08, 2003 10:15 am
by Pix Doc
Lots HERE... http://forums.genvibe.com/zerothread?id=3317Including my tips and pics! Pix Doc
Re: De-Badge (Pix Doc)
Posted: Tue Apr 08, 2003 11:56 am
by 30yr_old_fogey
OK, the de-badging was a success. Here's my two cents:1) Use the hair dryer - it's easier to get them off this way.2) I used a plastic scraper normally used for ceramic cooktop cleaning.3) Use "Oops Latex Paint Remover" - it works better than Goof-Off and 3M Adhesive and Wax remover.4) Take your time! Don't work the remover solvent too hard, it will dull the surface a bit.5) Use a spotlight at an angle to see how your doing.6) I found that using a "cleaner wax", then wax, then detailer totally eliminated all signs of the badges' existence.It took 2 hours. Oh, and 5 minutes extra trying to formulate some kind of clever word with the removed lettering, but not much you can do with "vib", "e", "g", and "t".Thanks for the original thread, also.
Posted: Fri Apr 11, 2003 5:32 am
by robdog
It took me 30 minutes. 20 lb test fishing string and some goof off. No scratches, No glue, Looks real nice!
