Power window lockout problem
Posted: Mon Jul 15, 2002 8:23 am
by HenryTS
I figured I would ask here before going to the dealer-when I have the passenger lockout on for the power windows I can't operate them from the drivers door either. The only way I can raise or lower the passenger windows is if I turn the lockout off first, From the sounds of the manual I should be able to raise and lower the passenger windows from the drivers controls even with the lockout on-is there something wrong with my setup?
Re: Power window lockout problem (HenryTS)
Posted: Mon Jul 15, 2002 8:33 am
by NSimkins
quote:...I can't operate them from the drivers door either. The only way I can raise or lower the passenger windows is if I turn the lockout off first....Mine does the same thing. I will have to take a look at the manual, but maybe it was either a misprint or just the way it is designed.
Re: Power window lockout problem (NSimkins)
Posted: Mon Jul 15, 2002 11:13 am
by NovaResource
That's normal and how mine works as well.
Re: Power window lockout problem (NovaResource)
Posted: Mon Jul 15, 2002 11:53 am
by Lori19
That's how mine works but I sure don't like it or consider it normal! I'm always using the lock out on my 7 year old, but when I unlock it for me he zips right to the button.
Re: Power window lockout problem (Lori19)
Posted: Mon Jul 15, 2002 9:19 pm
by NovaResource
I meant it was normal for all Vibes.
Posted: Tue Jul 16, 2002 1:28 am
by Frosty
It was that way for my Honda Civic as well. There must be some safety reason for it that escapes us
Re: Power window lockout problem (kshields)
Posted: Tue Jul 16, 2002 1:18 pm
by Lori19
The Grand Am didn't do this. Why they didn't do the same for the Vibe is beyond me.
Posted: Tue Jul 16, 2002 11:29 pm
by BanditWS6
Since the engineering of the Vibe's interior controls is pure Toyota, I have to guess it may be a Japanese automaker perspective on how the window lock should function. Any American car I've ever driven with a window lock function (mostly Fords) allowed the driver to control all the windows while the lock was engaged.Anyone with experience with Japanese cars might know if the Vibe uses the standard design for such vehicles. Truth be told the Vibe is the first car I've owned that was largely Japanese.
Re: Power window lockout problem (BanditWS6)
Posted: Wed Jul 17, 2002 1:04 am
by Frosty
Perhaps some wizard on this board could figure out a way to allow the driver the power by rewiring the lockout button. The driver's controls would have to be wired ahead of the lockout. Don't know if there is an easy way to do this without comparing the Grand Am to the Vibe wiring diagrams.
Posted: Wed Jul 17, 2002 7:48 am
by HenryTS
hmmm-after re-reading the manual it seems vague and even confusing to say the least. It says "The driver can still operate the left front passenger window with the lock-out button pressed". Ummmm--wouldn't the left front passenger window be the driver's window?
Posted: Wed Jul 17, 2002 9:24 am
by NSimkins
quote:It says "The driver can still operate the left front passenger window with the lock-out button pressed". Ummmm--wouldn't the left front passenger window be the driver's window?Yeah, I read that and had to reread it a few more times just to make sure I understood what I saw.So apparently the manual is correct depending on how you read that sentence.
