Lineage Grounding Kit
Posted: Tue May 27, 2008 10:38 am
by rsaxman
I just received the kit for my car today. Does anyone have any decent pics of the install? The instructions are quite vauge and I couldn't find any good pics on here when I did a search.Thanks
Re: Lineage Grounding Kit (rsaxman)
Posted: Tue May 27, 2008 10:46 am
by 02csnow
Well Bluecrush did a how-to-install on it, but all the pics have been removed. That is the only thread that I know of.I actually recieved my new one today and will be installing it soon. I had one before but decided to change colors. Sorry that I do not have any pics of the old install.It all depends on what kind you got. Some have a little disc that you put on the battery and all the wires branch off from there. Then there is one that has a wire that jumps from point to point.
Re: Lineage Grounding Kit (02csnow)
Posted: Tue May 27, 2008 10:41 pm
by rsaxman
Mine is the one that jumps from point to point. How did you have yours set up before? What engine parts and which order did you connect to?Thanks
Posted: Wed May 28, 2008 4:55 am
by 02csnow
If it's the one you can get off ebay. Use these measurements and points. They are from the thread I was talking about.Courtesy of Bluecrush-I used the 18" from the alternator bracket to the passenger's side chassis.I used the 22" from the driver's side chassis, under the stock airbox to the battery negative terminal.I used the 26" from the passenger's side chassis to the rear valve cover. I used the 32" from the negative battery terminal, under the battery to the tranny.I used the 38" from the rear valve cover to the trannyPretty much, you want to get a point on the chassis, the tranny, the - battery, and the valve cover. Make sure they are continuous.
Posted: Thu May 29, 2008 3:36 am
by BlueCrush
I have a new Lineage kit installed. I'll take new pics of my contact points this weekend and post them up on my original install instructions thread.
Re: Lineage Grounding Kit (BlueCrush)
Posted: Thu May 29, 2008 7:41 am
by rsaxman
Sweet! Thanks
