First try On new lights
Posted: Tue May 27, 2008 12:52 am
by kittyboop
So I got some HIDs for my birthday for my car, pretty cool gift to me.They are moving hi/low and I get to keep my DRL.Well, first attempt at putting them in....Went in no problem, First light on passenger side but it, looked great...Second one in ondrivers side, installed finished, turn lights on, driver side is out came to the conclusion it was the ballast.putting in a new one today, wish me luck!
Posted: Tue May 27, 2008 1:31 am
by northvibe
so the HID's have high/low and drl?
Re: (northvibe)
Posted: Tue May 27, 2008 1:45 am
by Fastvibe03
My canadian Vibe have automatic lights, so the low beam is the same of DRL.Northvibe, do you change the side of the connector on the default ballast?Try it
Posted: Tue May 27, 2008 2:39 am
by northvibe
the main issue I see is HID's and DRL. Its just a lower voltage than low beam (usually) or just lowbeam. My HID's in my ms3 are not hi/low, just low and my high beams are normal bulbs. Most people that get HID's disable the DRL on the vibe and just manually turn them on.Fastvibe03 - I cannot answer that as i never had HID's in the vibe. sorry.
Re: (northvibe)
Posted: Tue May 27, 2008 9:57 pm
by kittyboop
I have hi/low and my daytimes still run as do the automatic light feature. Same as always, just cooler bulbs.My earlier issue was it wasn't grounded right. Happy about that, we thought is was the ballast.
Re: (kittyboop)
Posted: Wed May 28, 2008 12:03 am
by Whelan
Do yourself a favor, disconnect the battery, do the install, connect battery and try the lights before you finish the work. Then complete the install. I did this for my set as per the instructions and it worked fine.Also you will notice that DRLs are never an option with HIDs. Luxury cars that utilize HIDs and have DRLs use a regular bulb for DRL. Just think about it.
Re: (Whelan)
Posted: Thu May 29, 2008 3:21 am
by Fastvibe03
Whelan say the truth, HID don't have DRL option.On Vibe, DRL work fine with HID btw.
Re: (Fastvibe03)
Posted: Thu May 29, 2008 9:11 am
by 02csnow
Quote, originally posted by Fastvibe03 »On Vibe, DRL work fine with HID btw. Yeah, until after a year when the bulb blows. So there goes another $50 for bulbs.
Re: (02csnow)
Posted: Thu May 29, 2008 9:45 pm
by Fastvibe03
I have HID on my Vibe since a year an a half and i didn't had any problem...Bulb are 40$ + shipping.
Re: First try On new lights (kittyboop)
Posted: Mon Jun 09, 2008 1:06 am
by kittyboop
they are working fine, and I tried to do a comparison when the DRLs and switching the headlights on and so far, i cannot tell the dfference. Who knows, maybe my eyes are bad, lol.
Posted: Mon Jun 09, 2008 2:35 am
by Sublimewind
Quote, originally posted by kittyboop »they are working fine, and I tried to do a comparison when the DRLs and switching the headlights on and so far, i cannot tell the dfference. Who knows, maybe my eyes are bad, lol. You'll not likely see a difference, if it was the original incandescent bulb sure, a power decrease will equate to a dimmer bulb, but, in the ballast for the HID, they usually compensate for lower power, to a point, then they'll go out... It would be best overall to disable the DRL just so you aren't stressing the ballast..
Re: First try On new lights (Sublimewind)
Posted: Mon Jun 09, 2008 6:48 am
by satur9
actually it depends on the hid kit.the kit i bought. had the ballast go to the battery the original headlight socket wiring just powered a relay.these kits work brn up stock wiring or burn out because of drl
