What is wrong with my air conditioner and heater blower?
Posted: Fri May 23, 2008 8:08 am
by Hellga
So, sometime around August of last year, I read about the trick where you contort yourself into an uncomfortable position and fiddle with the bits under the glove box, to make the AC blow colder (or something like that). I printed out the page, followed it to the letter, and it worked...for like, 5 days.Now, it still looks the same underneath. My handiwork is still accomplished.HOWEVER:1: The blower no longer blows until the dial is set to 3. That's 3 out of a whole 5 I have to choose from. At 5, it now blows about as well as it did on 3 last year. If you own a Vibe, you should know how hard it is to cool it anyway...now imagine you can't turn it past 3!!!!2: The stuff under the glove box rattles and vibrates and generally makes an (removed) of itself when the blower is going. I can stop the vibration with my foot when I'm in the passenger seat, and that tones down the noise, but it's really frustrating.Can anyone help me? The freon (frion?) is still good and at a good level, we checked it. I really don't want to have to pay someone to fix this problem, and it's definitely not under warranty anymore, so I really would like to fix this myself. Any ideas at all?Oh, also, my vibe is a 2003 model, FWD, and I don't know what other info you'll need. It's blue?:-D
Posted: Fri May 23, 2008 8:17 am
by WaveAction
going by the first thing you posted about it only blows on the 3 or higher..you musta done something and blew the resister in it..its a common thing for pontiacs to do it..my sunfire did it and it was easy to replace..not sure how difficult it is on the vibes though
Posted: Fri May 23, 2008 9:20 am
by zionzr2
the Blower motor resistor has failed and you will need to replace it! There are a few threads already on that issue. A search should locate these threads quickly.
Posted: Fri May 23, 2008 9:56 am
by Hellga
Thanks, both of you! I'll find some of those threads and hopefully get the problem fixed before the temps get up into the 90s here in a few weeks...blech.
Posted: Wed Aug 06, 2008 7:52 am
by Hellga
Okay, I've asked at like 379 auto parts stores, and the general consensus is that the Blower Motor Resistor doesn't exist.Can someone please tell me where to get it, or at least a part number? We're dying of heat here!
Re: (Hellga)
Posted: Wed Aug 06, 2008 7:57 am
by kevera
It does exist.This is the new part#1580202{replaces 88970279 #88970279, 88973260}*Try both part numbers on your search*Try checking the dealer for a price or hit up Rockauto.com.They have them there for #31.99.
Re: (kevera)
Posted: Wed Aug 06, 2008 8:08 am
by scherry2
here is a link to a picture. http://forums.genvibe.com/zerothread?id=23496its toward the bottom of the page
Posted: Wed Aug 06, 2008 9:16 am
Also, if it blows on "3" but doesn't seem to put out anymore air on "5" you might have a nasty cabin air filter. See http://forums.genvibe.com/zerothread?id=982 on how to check it
