hub centric rings
Posted: Thu May 22, 2008 4:16 pm
by clp
If i buy custom 17 inch wheels do i have to have the hub centric rings or are they just an option?
Re: hub centric rings (clp)
Posted: Thu May 22, 2008 9:28 pm
by Raven
You'll need the rings 99.9% of the time. They're only about $15.00 a set. I got mine from Discount Tire I believe. They are definately not an option, they're a necessity.
Re: hub centric rings (Raven)
Posted: Thu May 22, 2008 9:38 pm
by joholste
i think if you buy wheels from tire rack.com they automaticalyy give you the rings for free
Posted: Tue May 27, 2008 11:24 pm
by Jyik40
Hubcentric rings are very important. If you don't use them, your wheels can be mounted off-center causing vibrations when you reach highway speeds.
Re: (Jyik40)
Posted: Wed May 28, 2008 5:02 pm
by RSTuningFactory
Quote, originally posted by Raven »You'll need the rings 99.9% of the time. They're only about $15.00 a set. I got mine from Discount Tire I believe. They are definately not an option, they're a necessity.I ordered one wheel from discount, they came with one set of 4 rings for free.
Re: (RSTuningFactory)
Posted: Thu May 29, 2008 12:47 am
by hskater26
my wheels still shake with them and they are balanced correctly
Re: (hskater26)
Posted: Fri Jun 06, 2008 4:55 am
by darcmater
so i was lookign at my papwerwork today on my rims and didn't notice a listing on it for hubcentric rings, so Iw ent down to my local discount tire where I got them from and the guy behind the counter said they have nominal use, but that I could get a set for like 15 bucks if I wanted. He made it seem as if they didn't make a naticeable differance. My steering wheel does vibrate a little at highway speeds, but for all I know that could just be from the wodner michigan highways. So should I get some, I mean its only 15 bucks or so?
Re: (darcmater)
Posted: Fri Jun 06, 2008 9:16 am
by Raven
If the hub of the wheel is a different size than the hub on the car then definately get them. The Vibe is made to be hubcentric not supported by the wheel studs.
Re: (hskater26)
Posted: Fri Jun 06, 2008 9:18 am
by Raven
Quote, originally posted by hskater26 »my wheels still shake with them and they are balanced correctly If that's the case you must have a tire with a bad belt or a bent wheel. Properly balanced and installed wheels don't shake.
Posted: Fri Jun 06, 2008 9:26 am
by WaveAction
most aftermarket rims should come with the hub ring..if not..then thats weird..
