Quick question regarding engines
Posted: Sun May 18, 2008 6:53 am
by slvgt
I was just wondering how the vibes engines changed from 04 to 06I am looking for a vibe engine, but when I search on car-parts.comIt says that the 04 and 05 are differentHow so?
Posted: Sun May 18, 2008 6:57 am
by northvibe
engine is exactly the same, the only change for the 1zz was drive by cable (03-04) to drive by wire (05+)the 2zz in 2004 had the added "smog pump", called it air something or other. Otherwise also the same engine.
Posted: Sun May 18, 2008 7:22 am
by slvgt
Ok Thanks,I was going to put the engine in my celica, and wanted to make sure that it was the same.As far as drive by wire, I would be swapping my drive by cable throttle body on anyway
Re: (slvgt)
Posted: Sun May 18, 2008 7:27 am
by northvibe
Quote, originally posted by slvgt »Ok Thanks,I was going to put the engine in my celica, and wanted to make sure that it was the same.As far as drive by wire, I would be swapping my drive by cable throttle body on anywayAh 1zz, yup then all you need to do is swap your TB and it shouldnt be a issue.
