Aftermarket Cruise Control
Posted: Fri May 16, 2008 10:49 am
by DC3
This afternoon we picked up an almost-new 2007 base Vibe. I've been driving cars for 60 years and buying them for 40 but somehow I let one slip by me this time. I did not realize 'til I was driving away from the dealer's that my car has no cruise control! I just assumed it did. How much difficulty is involved in retro-fitting cruise on a 5-speed?DC3
Re: Aftermarket Cruise Control (DC3)
Posted: Fri May 16, 2008 11:54 am
by zionzr2
Welcome to our Vibedom!I believe the '05 to '08 models w DBW just needed the stalk and plug it in.The '03s and '04 needed much more work as they were not DBW.A SEARCH will yield additional help!
Re: Aftermarket Cruise Control (zionzr2)
Posted: Sat May 17, 2008 12:09 am
by DC3
I appreciate your comment, Bill, but being a newbie about Vibes, I'm not sure what DBW means...please fill me in, if you will. One reason I bought the Vibe was for fuel economy and cruise control would surely help in that regard. Please...anyone...illuminate me on DBW!!dc3
Posted: Sat May 17, 2008 2:19 am
by kunkstyle
Drive by Wire. It's the same as e-gas. It eliminates the mechanical link between the accelerator pedal and the throttle, and is controlled electronically instead.
by nygiantzz1
DBW= Drive by Wire. There is no throttle cable, just a sensor and spring behind the gas pedal. Your Vibe is pre wired for cruise, you need to buy the stalk and install it in the steering column. The harness is inside the column.
Re: Aftermarket Cruise Control (nygiantzz1)
Posted: Sat May 17, 2008 2:30 am
by DC3
Many thanks to you guys! I discovered the super search feature and am now loaded down with tips on cruise controls ! I'm not the greatest with working in tight spaces any longer (eyes begin to get squirrely at my age!) so I think I'll call my dealer Monday and see if I can convince them they should do the mod for me. Wish me luck!And, again, thanks for the help. DC3
Posted: Sat May 17, 2008 2:57 am
by kunkstyle
Good luck! If your dealer won't do it, I'm sure you could find an independant mechanic that'll do it.
Posted: Sat May 17, 2008 4:41 am
by KNINE
If I can do it, I know the dealership can. I bought the stalk for $35.00. I think my dealer wanted $65.00 for it. labor shouldn't be more than two hours. I think it took me three, but I'm not the smartest pup in the litter.
Re: Aftermarket Cruise Control (K-NINE)
Posted: Sat May 17, 2008 5:53 am
by DC3
I live way out in the boondocks of the Blue Ridge mountains of western North Carolina. Nearest dealer's 50 miles from me. But just over the ridge is the independent ASE-certified mechanic who's kept every car we've had perking away for the last 15 years. I'm positive he can do it (if he will). All I need to do is order the stalk, right? Can I get that through my dealer or is the Rostra version better?DC3
Posted: Sat May 17, 2008 11:32 pm
by prathman
Quote, originally posted by DC3 »I live way out in the boondocks of the Blue Ridge mountains of western North Carolina. Nearest dealer's 50 miles from me. But just over the ridge is the independent ASE-certified mechanic who's kept every car we've had perking away for the last 15 years. I'm positive he can do it (if he will). All I need to do is order the stalk, right? Can I get that through my dealer or is the Rostra version better?Yes, all you need to buy is the stalk and you should get the GM/Toyota part. But see how much the dealer wants for it since it might be cheaper to get it elsewhere. http://www.rockauto.com usually has them for a pretty good price. The mechanic shouldn't have any problems doing the installation since it's pretty easy and quick. But print out some of the instructions you found with the search of this site. The only tricky part is that the green horn ground wire uses the same connector as the cruise control and has to be moved from its original connector to the one that comes with the stalk.
Re: Aftermarket Cruise Control (prathman)
Posted: Sun May 18, 2008 4:17 am
by KNINE
I bought mine from rockauto, and it looks exactly like the OEM stalk. The most important thing to remember is that the rockauto stalk does not come with the green ground wire for the horn. It must be removed from the OEM connector and transferred to the rockauto connector. Otherwise your horn will not work. That's why it took me three hours to do mine. I had to take everything apart and do it over again. The green ground wire will be obvious once the airbag assembly is removed.
Posted: Thu Oct 09, 2008 10:36 am
by VibeBear
Sorry for bringing back up an old topic, but does anyone know if the 09 Vibe's still have all the CC equipment.I only ask cause it's a re-design & it seems like something GM might *fix*
Posted: Sat Nov 28, 2009 9:26 am
by skywalker
Ok, This sounds redundant but I looked but they didn't have pics. This is all i need, a 40 dollar part? The green wire thing confuses me. On another site I saw stuff about cutting out holes how was that? Don't want it to look like the hillbilly next door did it! Thx for the help. Clint
