2006 AUTO TRANSMISSION PROBLEMS
Posted: Tue May 06, 2008 6:52 pm
by burbine67
i am having a problem with my automatic transmission after the car has been running about ten minutes the transmission is shifting hard ,the pontiac dealership thinks it a harness but i'm wondering if anyone has had this problem in the past .thanks
Re: 2006 AUTO TRANSMISSION PROBLEMS (burbine67)
Posted: Tue May 06, 2008 9:31 pm
by Kamikaze
Can't promise anything but you could try this:
http://forums.genvibe.com/zerothread?id=25238
Posted: Wed May 07, 2008 12:28 pm
by Petrucci914
Mileage? What is the fluid level at? What's the fluid color? Have you towed anything?
Re: 2006 AUTO TRANSMISSION PROBLEMS (Petrucci914)
Posted: Wed May 07, 2008 6:30 pm
by burbine67
heythe car has 71000 kilometers(canada)45000 miles,fluid is good do haul a small utily trailer once or twice a year no big weight though
Posted: Thu May 08, 2008 4:56 am
by blue_can
All gears or just going from one gear to another. Is it still under warranty. Have a line perssure check done (idle and stall) when the problem is there and compare to the specs. Hopefully the dealership (when they start working on diagnosing the problem) will actually do tests and take measurements rather than assuming what the problem could be.
