GatorBack & Idler Pulley Shims
Posted: Sun Apr 27, 2008 6:39 am
by Petrucci914
Hey,I just installed the GatorBack belt. It really must tighten a lot more. I had to take the idler pulley off and remove a shim as it was rubbing along the side. I do have to say it idles smoother now, the power seems smoother, and it whines a lot more. A good investment!
Re: GatorBack & Idler Pulley Shims (Petrucci914)
Posted: Sun Apr 27, 2008 8:57 am
by kevera
You got yours installed before mine ,hope I get the same results.I got my TB installed yesterday and it made a huge difference in my idle.
Posted: Tue Apr 29, 2008 5:02 am
by Celtic_Curse
Is there a problem with the belts or rough idle?
Re: (Celtic_Curse)
Posted: Tue Apr 29, 2008 8:56 am
by Petrucci914
Not entirely. The GatorBack has a better design so it will hold tighter around the pulleys, but it is also softer to reduce vibration. I saw it as a noticeable difference over the stock TRD/Dayco. It costs $32.
