Turbo Kit on EBay
Posted: Thu Apr 17, 2008 1:33 am
by skylinedrifter
I am thinking about picking this up but want some opinions. I can afford this kit... but I don't know if it's a "Too Good to be True" scenario.http://cgi.ebay.com/ebaymotors...ZWD1VTurbo kit include:T3/T4 Hybrid turbochargerGodspeed Type-L intercooler core (20.5x9x2.75)Universal 2.5" aluminum piping with silicone hose and clampsStainless steel turbo manifold (1ZZ-FE motor)Blowoff ValveFuel pressure regulatorOil return line and fitting5 bolt downpipe flangeT3/T4 Turbocharger specs:Inlet: 3"Outlet: 2"Bearing type: Wet float bearingOil inlet: 1/8 nptMax PSI capacity: 27PSICompressor: .50 ARTurbine: .63 ARCompressor wheel: * .57T Compressor wheel * Exducer: 3" * Inducer: 2"Turbine wheel: * .63 AR Turbine wheel * Exducer: 2.2" * Inducer: 2.58"Flange type: T3 flangeDownpipe flange Type: 5 bolt standard (.58)Max horsepower: 350HPNOTE: Customer is required to custom fit the intercooler pipings and make a custom downpipe in order to make this turbo kit work.
Re: Turbo Kit on EBay (skylinedrifter)
Posted: Thu Apr 17, 2008 1:58 am
by kevera
ebay turbo=JUNKDon't waste your moneyBuy this onehttp://www.turbo-kits.com/matrix_turbo_kits.htmlThere's a reason it's only a thousand bucks.
Re: Turbo Kit on EBay (kevera)
Posted: Thu Apr 17, 2008 3:22 am
by Raven
They have also been posted here more times than the HP they produce. AAAARgh!
Posted: Thu Apr 17, 2008 6:31 am
by skylinedrifter
*sigh*Honestly, I'd prefer a SC since I want better low-end performance but they're so expensive. A $1,000 turbo is affordable. Couldn't somebody soothe me with his sweet, sweet lies?
Posted: Thu Apr 17, 2008 9:11 am
by kunkstyle
When I saw the thread title I was waiting to see the electric fan in the air intake.
Posted: Thu Apr 17, 2008 9:14 am
by Lancer
You also need some sort of engine managment and a bung installed in your oil pan. So with al the custom work you'll need done for this kit to work, you might end up paying more then the ones Kevera posted.
Re: Turbo Kit on EBay (kunkstyle)
Posted: Thu Apr 17, 2008 9:17 pm
by skylinedrifter
lol... give me SOME credit, bro! I'm cheap, not stupid.
Posted: Sun May 11, 2008 2:06 pm
by Srouxd
This one doesn't work on the base models does it? the 1ZZ-fe Motor is what I have, i need a turbo for that, plus an ecu tune for a 2006 automatic.
