body kit
Posted: Mon Apr 14, 2008 11:55 pm
by Twizted-Vibe
I just bought a body kit ro my gt and was wondeing how hard the bumpers are to take off. what all is needed to take off the front bumper?also, how does the instrument cluster come out?
Re: body kit (Twizted-Vibe)
Posted: Tue Apr 15, 2008 5:18 am
by audiovibe
Instrument cluster is pretty easy, If you take to top of the dash off, unplug the harness to the cluster and then there are two speed clip tabs at the bottom of the cluster, just pop the cluster up with minimal force and its out.Here is a link with detailed instructions to get the top of the dash off Courtesy of Ragingfishhttp://forums.genvibe.com/zerothread?id=9977Ive never taken the bumpers off the vibe before but most cars just have a few bolts and mostly some sort of clips holding ithem on. Aron
Posted: Tue Apr 15, 2008 6:12 am
by keithvibe
the front clip is easy to take off three plastic retainer clips that look like philips head screwdriver heads.then the two hood bumpersthen there is a 10mm bolt at the point where the fender and the bumper meet in the wheel well. then there are two more 10mm bolts that hold on plastic shrouds for your wheel liners. then two more plastic push in clips up under the front clip. In all i think there are 14 fasners all together.. I can take my front clip off now in about 2mins... it's really easy to doI don't know about the rear bumper
Re: body kit (keithvibe)
Posted: Tue Apr 15, 2008 8:32 am
by damronjr
Quote, originally posted by keithvibe »I can take my front clip off now in about 2mins... it's really easy to doI don't know about the rear bumperSame here! lol The rear is not so bad, but kind of a pain. It has 2 bolts like the front bumper near the wheel well liner, and 2 under the car along the bottom. Then it has 3 or more in the middle, and you have to take the whole rear innards apart to get to them. The nuts are under the farthest rear cover and you have to get to them through small holes. I'm sure this doesn't help, but once you start tearing it apart hopefully it helps figure out where stuff is.
Posted: Wed Jul 16, 2008 5:06 am
by tribalman
i see from your current sig image that you also have the part that runs underneath the door twizted, how did you get that off?
Re: body kit (tribalman)
Posted: Wed Jul 16, 2008 6:58 am
by kevera
Quote, originally posted by tribalman »i see from your current sig image that you also have the part that runs underneath the door twizted, how did you get that off?You have remove the black retainers from underneath(I forget how many there are)and the 2 screws from either end in the wheel wells.Then you just pull it straight out because there is 1 clip at both ends.
