New Poster, H.I.D./Xenon Questions
Posted: Sat Apr 12, 2008 6:39 am
by Zer0VIBE03
Okay, so I bought my 03 Vibe about a week ago. Love it to death so far, easy on gas and insurance, stores all of my crap.I looked at the threads in here, but I can't seem to find it on my own. I want to eventually get H.I.D./Xenons and I tried searching on the web and ebay but can't seem to get any place that has prices and stuff other than "blinglightz" which I saw being made fun of in another thread. Where can I find a page online that actually has this stuff, for the Vibe, with prices and is a viable resource?P.S. if I am looking to modify anything by going through TRD, do I just basically shop for a 03 Matrix rather than an 03 Vibe?TYIA,Zer0.
Posted: Sat Apr 12, 2008 6:54 am
by Tonyk27
Posted: Sat Apr 12, 2008 8:00 am
by WaveAction
welcome to the forums, im purchasing HID's off of
http://www.thexenonstore.com/HID.php for $120 each kit
Re: New Poster, H.I.D./Xenon Questions (Zer0VIBE03)
Posted: Sat Apr 12, 2008 9:04 am
by kevera
I'd love HID's,but I won't disconnect my drl's.Too bad
Posted: Sat Apr 12, 2008 9:13 am
by WaveAction
personally i dont see why we'd have to disable the DRL's..HID use less power and stuff..and theirs a ton of cars out there that uses HID's all the time..such as cadillacs and acura
Re: (WaveAction)
Posted: Sat Apr 12, 2008 9:25 am
by kevera
If there was a way around it,I would get them.I seem to remember someone telling they had to be disabled,not totally sure on that though.
Posted: Sat Apr 12, 2008 9:43 am
by WaveAction
i guess we'll have to research, but alot of the higher up cars have HIDs as DRL's aswell, i personally dont see why we'd have to disable them, they use less power then a regular halogen bulb
Re: (WaveAction)
Posted: Sat Apr 12, 2008 9:46 am
by keithvibe
they do when they are at full power.... they require more power to start up. The drls only run at 80%. Because the drls are only running at 80% the ballasts don't have enough power to start.Thats why they strobe or flicker.
Posted: Sat Apr 12, 2008 9:49 am
by WaveAction
i see, so its best to disable the drl's? i dont see how the ballasts dont have enough power when they're supposed to be at 80%..what if you turned the actual headlights on when you start your car, so they can warm up and such..then turn them off..they would work properly after that??
Re: (keithvibe)
Posted: Sat Apr 12, 2008 9:50 am
by Kamikaze
Re: (Kamikaze)
Posted: Sat Apr 12, 2008 9:53 am
by WaveAction
Quote, originally posted by Kamikaze »
http://www.xenonrider.com has them bi-xenon too.seems kinda expensive for a bi-xenon kit..$260?
http://www.thexenonstore.com has a bi-xenon kit which comes with everything for $175
Posted: Sat Apr 12, 2008 9:57 am
by WaveAction
found this on that xenonrider site kami posted up Quote »Will DRL (daytime running lights) or Auto-Switch-On effect the HID kit?For vehicles with DRL (daytime running lights) that use the same bulb for both DRL and low beam, you will need to deactivate your DRL. Most DRL operate on reduced wattage or fluctuating current levels. This will cause the HID ballast and bulb to flicker and burn out prematurely.
Posted: Sat Apr 12, 2008 3:16 pm
by Zer0VIBE03
Recommended bulbs? 6000k or 9000k? I could live without the DRL's, I actually don't like that they are on when it's sunny out.
Posted: Sat Apr 12, 2008 10:20 pm
by WaveAction
6K or even 8K are the best way to go for headlights..im undecided on the HID's cause i dont wanna mess my warrenty up, brand new car so i'd hate to have something mess up and it not covered
Re: (WaveAction)
Posted: Wed Apr 16, 2008 12:41 pm
by Fastvibe03
I Zer0VIBE03, i sell HID since a year a half (see
http://forums.genvibe.com/zerothread?id=32654 ) i started group buy a it close shortly. Be in if you want i place order 25 april. I have a H4 HID kit on my 03 Vibe and i didn't disable DRL and i don't have any problem. Thanks
Re: (WaveAction)
Posted: Sun Apr 27, 2008 8:25 pm
by Mr. Joe
Quote, originally posted by WaveAction »6K or even 8K are the best way to go for headlights..im undecided on the HID's cause i dont wanna mess my warrenty up, brand new car so i'd hate to have something mess up and it not coveredIt won't affect your warranty. You can do prety much anything, as long at it dosen't alter the function. I was pretty happy to find out that even something like a CAI and catback won't void warranty. Those items would not be covered under your cars warranty of course, but they won't void it. On the HID's... I am planning on getting these the price is nice, and I have talked to several people who have purchased them and have not had any troubles.As for disabling the DRL's, I don't think it is necessary. it will just be at full power all the time. I would really like to find a way to disable the DRL's without disabling the auto-headlamp system. In either case, the ballasts can handle an input voltage as low as 9 volts, and the DRL voltage should be approximately 9-11.5 volts. (Based on the idea that the DRl system powers the bulbs at approximately 80% of the standard voltage, and standard voltage is between 12 and 14.5 volts.) I plan on getting the 6000k system because the 8000k system tends to produce less visible light with the blue'er color. I considered the 4300k because they claim that it has the best light output, but I'm near 4100k with my SilverStar Ultras now and they still aren't nearly as good as my Vue's that are near 5000k with a similar rating in lumens.
Re: (Mr. Joe)
Posted: Sun Apr 27, 2008 10:07 pm
by Whelan
1) my pictures are all over this site so I won't post them again.2) my kit is MUCH cheaper cause I own a Matrix, which utilizes a dual lighting system where two bulbs one for high and one for low work, instead of the Vibe that uses a single bulb with two filaments for both purposes. ($70)3) 6K equals a more white look, 8K is noticeably bluer. 4) Stock OEM HID kits are 4300K, the coloring is due to the projector lens type.5) Once you put them in, you will NEVER drive another car without them.
Re: (Whelan)
Posted: Mon Apr 28, 2008 6:28 am
by Fastvibe03
I agree with you Whelan.
