Steering to the left and "light" steering
Posted: Wed Apr 09, 2008 9:00 am
by michaelj1978
Test drove an 05 today that I'm looking at buying and when you let go of the wheel it wants to go left. Also when you brake the steering shutters back and forth (with hands off the wheel). It also has a very light front end feel? Is this normal (the light front end)?Also do you think it's just an alignment issue? It's a 1 owner car with only 45K on it. Needs new tires and I will get them aligned correct when I get the new tires on it?
Re: Steering to the left and "light" steering (michaelj1978)
Posted: Wed Apr 09, 2008 9:06 am
by kunkstyle
Sounds like alignment or a tie rod end. If you're serious about buying it, why not get a ppi done on it?
Posted: Wed Apr 09, 2008 9:17 am
by michaelj1978
what is a ppi?
Re: (michaelj1978)
Posted: Wed Apr 09, 2008 9:26 am
by Raven
I'm guessing pre-purchase inspection.
Re: (Raven)
Posted: Wed Apr 09, 2008 9:30 am
by kunkstyle
sure is.
Posted: Thu Apr 10, 2008 4:10 am
by Sublimewind
Quote, originally posted by michaelj1978 »Test drove an 05 today that I'm looking at buying and when you let go of the wheel it wants to go left. Also when you brake the steering shutters back and forth (with hands off the wheel). It also has a very light front end feel? Is this normal (the light front end)?Also do you think it's just an alignment issue? It's a 1 owner car with only 45K on it. Needs new tires and I will get them aligned correct when I get the new tires on it?The stuff in bold directely relates to:A. AlignmentB. Warped brake rotors (out of round drums)Both are easy fixes, get an alignment and get a brake job... The light feeling is prolly just you not being familar with the car, my Subaru is MUCH heavier in the front end compaired to the Vibe... What are you driving now, to compair to??
Re: Steering to the left and "light" steering (Sublimewind)
Posted: Thu Apr 10, 2008 4:55 am
by AZViking
Re: Steering to the left and "light" steering (AZViking)
Posted: Thu Apr 10, 2008 8:36 am
by Mavrik
1. tire pressure or alignment issue2. brake rotor warped.
Posted: Thu Apr 10, 2008 9:58 am
by Raven
Quote, originally posted by AZViking »Would the light front end be in any way releated to electric power steering (2005)? I test drove an Equinox a couple of years ago and it felt like I was in a simulator (steering didn't feel connected to the car).I could be wrong, I thought I'd heard that 05+ have electronic throttle and power steering.Negative on the electric steering.
Re: Steering to the left and "light" steering (Raven)
Posted: Fri Apr 11, 2008 4:27 am
by michaelj1978
Turns out the front driver side tire was at 15psi....Didn't even think to check it so took it to my local shop, they checked the entire car out for any accidents, all the brakes etc for just $50 and found the problem. Good piece of mind...I ended up getting the car and am picking it up on Monday.
Posted: Fri Apr 11, 2008 5:26 am
by Mavrik
Quote, originally posted by michaelj1978 »Turns out the front driver side tire was at 15psi.... yup, that can cause a pull.
